It is currently Fri Jun 26, 2026 5:28 am
 Post subject: OffenHauser Gasket?
PostPosted: Mon Mar 08, 2010 1:57 pm
Hey guys i realized my intake is leaking into carb. Wet/black out of tail pipe and she is back firing and leakin a little topside against block front of truck near the raiator hose conection. Any way cant remember if i just use stock one. Wanted to know before i pull it all off. Mokadeath you around?
Thanks in advance.
ox
 Post subject: Re: OffenHauser Gasket?
PostPosted: Tue Mar 09, 2010 1:22 pm
Cant remember what I did last time. Think the holes were a little different. Anyone have any ideas? Not sure when im goiing to pull it off just wanted to gather stuff before pulling it off. OR was it just a tube gasket job?
PostPosted: Tue Mar 09, 2010 7:24 pm
Seems to me it was a stock gasket if I remember right. Even if the ports were bigger than stock on the Offy it's still the same head. Worse case I would think you could just remove any gasket material to match the manifold.
