It is currently Mon May 25, 2026 8:18 am
PostPosted: Thu Feb 18, 2010 8:14 pm
has anyone used one on their air suspension for the luv? i have viar 380s on my s10 but i what the edc for my 78.
PostPosted: Thu Mar 04, 2010 12:32 pm
wow nobody has done this before :lol: i think ima doit or atleast try.lol
PostPosted: Thu Mar 04, 2010 2:25 pm
just use the factory AC brackets and use a sanden 308 converted to compressor duty. and there you have it.
I think the main reason nobody ever has is because the stock 1.8 is such a dog. I think the added load of running a compressor would only make life WAY harder for an already crappy engine.
A.j.
PostPosted: Fri Mar 05, 2010 1:14 pm
yeah thats true. thats what i figured.i was thinking just what u suggested but i havnt been lucky in finding a double v belt pulley to attach to my alternator. im not sure if killbys makes one
PostPosted: Fri Mar 05, 2010 1:55 pm
it wouldnt be hard to just convert your factory alternator to use a GM 1 wire. dual groove pulleys are easy to find for that application and it improve your charging ability.
A.j.
PostPosted: Fri Mar 05, 2010 10:26 pm
were can i find it?
PostPosted: Fri Mar 05, 2010 11:54 pm
I'm putting in that compressor for an AC swap and if you want 2 groove then you'll need a dual/triple groove for the crank and 2 for the water pump pulley as well right? But I haven't done anything about that I am just using one groove out of 2 on the AC compressor. I've got it in the belt drive system without being plugged in, no problems here. We'll see what happens when I get done and the system is charged.
PostPosted: Tue Mar 09, 2010 9:16 am
what i was thinking take out the ac comp fab up some brackets and meke it work with the alternator pulley. just havnt found the pulley that i want.
PostPosted: Fri Mar 12, 2010 1:25 pm
I used Kilby for my Jeep compressor I believe if you look on there site they do have the V belt pully. I used the the York 210 and can run air tools with it! Good luck sound freaking cool.
PostPosted: Sun Mar 14, 2010 9:04 pm
i checked killbys but didnt see it im gonna check it out.i was thinking of running the same compressor.thanks thoe
PostPosted: Mon Aug 09, 2010 11:02 pm
I've got a York 210 for sale $100 and it's new. I'm in Oxnard. You can run it off a double alternator pulley. We did that on my friends Buick. Works awesome
