It is currently Sun Jan 18, 2026 6:34 pm
Post new topic Reply to topic  [ 94 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: kaotikl luv
PostPosted: Mon Feb 08, 2010 5:40 pm
PostPosted: Mon Feb 08, 2010 7:42 pm
give yalla heads up on tinights adventures...tonights adventure includes rocker choppin,bracin the cab up for the floor and firewall to come out and body dropin the cab 4 inches..hope to have pix up of to nights adventures up maybe tomorrow or the next day
Epic Fabrication.
KAOS
PostPosted: Mon Feb 08, 2010 10:08 pm
So are your new arms shorter than stock. Don't the s10 spindles stick out a lil farther than the luv spindles? I know I need to make my arms an inch shorter for my toyota spindles. Kick ass build. You going down to the door? Or flat rocker?
PostPosted: Tue Feb 09, 2010 7:17 am
naw my arms are stock length..and in goin bout a half inch below the bottom of the door..and far as my adventures last night the didnt og as planned only got the cab braced up fot the stuff to get cut out...gonna swop shops this week and next week ill make progress
Epic Fabrication.
KAOS
PostPosted: Tue Feb 09, 2010 8:02 am
ok here we go got some ? if any one can answer them has any one ever used the ezwiring 18 circuit wiring harness vs. the painless 18 circuit? whats the pros and cons of them...other than the price....and got good news my master cyclinder will be here today..and my new headlights will be here..can waint to see what they gonna look likeon the luv
Epic Fabrication.
KAOS
PostPosted: Wed Feb 17, 2010 5:27 pm
ok made progress so far got the rocker off
Epic Fabrication.
KAOS
PostPosted: Wed Feb 17, 2010 5:39 pm
her ethe pix are
Epic Fabrication.
KAOS
PostPosted: Wed Feb 17, 2010 6:43 pm
goin to pik up another luv sat its a 80 model 4spd..jus needs the timin set and imma use it as a parts getter the body is in prety good shape except like 6in on the bed and the nose of the hood has like 3 spots rusted thru..
Epic Fabrication.
KAOS
PostPosted: Tue Feb 23, 2010 8:21 am
hey where do you get the sheet metal parts like rocker panels and stuff i have been looking every where and cant find them
PostPosted: Mon Mar 01, 2010 4:41 pm
scratch that didnt get it funds went dry..
Epic Fabrication.
KAOS
PostPosted: Mon Mar 01, 2010 4:54 pm
Would you be able to take pics of the front completely on the ground? You say you didnt have to Z and your laying flat because of your spindles and you have more drop in the control arms. I believe you are sitting on the crossmember and by the way the pics in teh grass, you are not laying flat its up in the front laying on the crossmember. Thats why you believe you have more room in your control arms to go down its because your not completely on the ground. I am not trying to be a dick but you are giving people miss conceptions about the build.
"You know you gotta LUV me"
PostPosted: Mon Mar 01, 2010 5:05 pm
oh u str8 ill try and get some more pix of it..my laptop is down at the moment and thats how i get my pix up so it might be a min but im tellin u it lays flat..cept like a 8th of a inch the lil things on the bottom of the tranny xmambe are holding it up..gota gring those off then it flat all the way to the front
Epic Fabrication.
KAOS
PostPosted: Mon Mar 01, 2010 10:27 pm
kaotikl is right, if you have drop spindles you don't have to Z the frame. If he kept stock 6 lug he would have had to Z because they don't make spindles for luvs, checked into when I body dropped mine
PostPosted: Mon Mar 01, 2010 10:34 pm
Thats right I didnt take the 5 lug into consideration!! Ok you got me on that one
PostPosted: Tue Mar 02, 2010 6:20 pm
hey bagged79 got any pix of your body drop..cause im in the process right now of cuttin the rockers off and finna start plannin my body drop ani i was jus wantin a lil insight??
Epic Fabrication.
KAOS
PostPosted: Wed Mar 03, 2010 1:18 pm
You stock flooring or traditional?
PostPosted: Wed Mar 03, 2010 4:47 pm
im jus gona rebuild the whole floor only thing im usung thats original is the mounting holes everything else is gona be new sheet metalpretty much have the concept was jus wonderin bout round the door jams
Epic Fabrication.
KAOS
PostPosted: Wed Mar 03, 2010 8:53 pm
I stock floored mine, only had to cut and extend the trans tunnel. I have pics under my build-up topic!
PostPosted: Thu Mar 04, 2010 7:27 am
yeah looked at them last night but couldnt really see round the doors saw where u moved the trans tunnels and all...
Epic Fabrication.
KAOS
PostPosted: Thu Mar 04, 2010 8:34 am
well jus aheads up i went a head and had my rear end shortened 2 1/2 inches
on each side and had new axles made for it wasnt a bad deal only cost 400..cheaper than any other place i called they wanted 375 jus to cut the housing
Epic Fabrication.
KAOS
