It is currently Mon May 25, 2026 10:03 am
 Post subject: Air Dam
PostPosted: Sun Feb 21, 2010 7:26 pm
While I let my thumb heal a bit with the suture in it, I am pondering the front air dam. Is there a shape that allows one to be effective without destroying fuel economy? I look at WildLUVRacing74's and see a wall there. NASCAR has pretty much the same thing. Is this designed only for speed and/or holding the vehicle on the track? Allowing only so much air pass under the truck while diverting the rest to the sides and over the truck is a tricky formula I'm sure an engineer would be hard pressed to figure out. Ctmandu fabricates the old style I am used to (JCWhitney sold some with the fender flares) that I am leaning towards, but would like to change the shape just a bit to 'update' the look. This is where I don't want to create a bill board effect up front. Ideas, hints, designs, don't give a rat's butt? Thanks..
Rick
Loranger, La
1980 Stepside LUV (Again)
 Post subject: Re: Air Dam
PostPosted: Sun Feb 21, 2010 7:34 pm
Not sure what you are looking for but my truck came with this one on it.
PostPosted: Mon Feb 22, 2010 4:55 pm
I cut one up from an s10. Let me see if I have a pic...
PostPosted: Mon Feb 22, 2010 5:59 pm
I like Scott_mcd's, but leave out the brake vents. Nice and bold! Does sit come straight down or have an angle built into it?
Rick
Loranger, La
PostPosted: Mon Feb 22, 2010 6:20 pm
Here is the one from the s10
PostPosted: Mon Feb 22, 2010 6:44 pm
Hey Luvit80, is the air dam attached to the bumper? I have no valance to attach anything to. I might combine the size of the one on Scott_mcd and yours. Guess I will be sneaking in some planing on the truck this week behgind the wife's back.
Rick
Loranger, La
PostPosted: Mon Feb 22, 2010 6:53 pm
It is attached to the bottom of the bumper. Here is another pic of the same damon a different truck. You do have to cut a notch in the air damn to clear the frame mounts for the bumper. Not the best pics but gives you an idea...
PostPosted: Mon Feb 22, 2010 8:08 pm
The rubber ones that out under Chevy full sizes were for improved fuel mileage.
PostPosted: Mon Feb 22, 2010 8:11 pm
Mine, it doesnt bolt to the bumper, got it in 85.
as for aero and all that, well they are suppose to help but I couldnt give a crap either way, I bought it because they look cool! :esurprised
PostPosted: Mon Feb 22, 2010 8:55 pm
It has an angle. This is the best pic of the angle that I have right now. If you want a better pic of it let me know.
PostPosted: Tue Feb 23, 2010 12:32 am
here are some i will be working on ... plus the others on my site
PostPosted: Fri Jan 28, 2011 11:50 pm
i came across this thread while looking for a new air dam for my truck. i sort of scrolled through some forums and sites as well. found these ones by JSP brand. i hope they're any good.
_________________________________________
1999 jeep grand Cherokee Limited
Eclipse CD7000
1995 Mazda Protege
Eclipse CD7100
PostPosted: Sun Mar 20, 2011 12:32 pm
are those 50" side pipes? i need to replace mine but im in germany and its in washington, so i cant measure.
PostPosted: Sun Mar 20, 2011 1:13 pm
They were 60" pipes. I took them off and had dual exhaust ran out the back.
Users browsing this forum: Google [Bot] and 17 guests
