It is currently Mon Jun 08, 2026 10:44 am
 Post subject: Upgrading valves?
PostPosted: Fri Feb 12, 2010 8:10 pm
Looking through several manuals it looks like the G180, G200, 4ZD1 & 4ZE1 all have the essentially the same overall valve length and shaft diameter, the valve head diameter just gets progressively larger as the series gets newer. I know you can retrofit the G200 valves & seats into a G180 head and the 2.6 into the 2.3 head, but can you go even farther? Is there enough metal to put the 2.3 or even the 2.6 valves & seats into an early head? You could increase the air flow substantially if it were possible.
 Post subject: Re: Upgrading valves?
PostPosted: Sat Feb 13, 2010 12:19 pm
this might be a question for the guys at ozgemini.com,I'm interested if this would work as I am wanting to max out my g180 rather than doing an engine swap.
76 mikado project,mean green
