It is currently Tue Jun 30, 2026 9:36 pm
 Post subject: DOAN Cushions??
PostPosted: Tue Feb 09, 2010 11:09 pm
from powerbyace.com
"V8 Engine adapters pair R/L Bolt in, easy installation, no welding. Use DOAN 2142 or 2267 cushions. 2 WD & After market 4 WD. Instructions included"
is that a brand name? im not entirely sure what it means by this description
 Post subject: Re: DOAN Cushions??
PostPosted: Wed Apr 28, 2010 1:16 am
I just ran across this post, hopefully you have got your answer by now. But if you didnt, just go to autozone or any parts store and ask for the part#, i think its 2142 for the V8 convert. I had the same problem.
http://www.autozone.com/autozone/catalog/parts/partsProduct.jsp?itemIdentifier=153668_0_0_&skuDescription=Duralast+/+Motor+Mount&brandName=Duralast&displayName=Motor+Mount&categoryNValue=14399999&sortType=&store=3753&isSearchByPartNumber=true&fromWhere=&fromString=search&counter=0&itemId=154-0&navValue=14300154&filterByKeyWord=2142&productId=153668&searchText=2142&categoryDisplayName=Collision,+Body+Parts+%26+Hardware&parentId=43-0
Chevys, Harley Davidsons, and Blonds.....I only ride the best.
DEATH BEFORE LIFT!!!
PostPosted: Wed Apr 28, 2010 8:33 am
DOAN was the brandname a while back jus got to the parts store site and type the numbers if the doan cusion and they will come up if i can rem right when i bout my cushions they were made by anchor..Use DOAN 2142 or 2267 cushions....look it up using either 2142 or 2267..
Epic Fabrication.
KAOS
PostPosted: Thu Apr 29, 2010 6:23 pm
How strong are these mounts? I'll be putting alittle over 600hp on these mounts.
PostPosted: Fri Apr 30, 2010 9:55 am
being that there are basicly only 2 sizes of chevy motor mount used in the last 43 years its easy to find what you need.
for the guy who was worried about strength, heres basicly everything you need to use the "POWER BY ACE" motor mount system.
http://www.summitracing.com/parts/ENS-3-1120G/
A.j.
PostPosted: Sun May 02, 2010 6:03 am
Thank's alot, I've got the Powerbyace mtns and trans mtn already and these that you have suggested should be just what I'm looking for.
PostPosted: Fri Jun 11, 2010 8:21 pm
Got my mtns in from summit and they look great and fit the Powerbyace stuff I have perfect. Now I have to fab up a trans crossmember for the 350 turbo with a 208 transfercase thats one thing I didn't consider about the 4 wheel drive stuff on this conversion.
