It is currently Sat Dec 13, 2025 12:57 pm
Post new topic Reply to topic  [ 107 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Post subject: Re: Project DirtyLuv!!!
PostPosted: Sun Jan 17, 2010 2:47 pm
ebay for fuel cells thats where im going to get mine.
PostPosted: Sun Jan 17, 2010 4:49 pm
Yea its just hard I want to get a 12 gallon but there all too big for the area I have.
"You know you gotta LUV me"
PostPosted: Thu Jan 21, 2010 5:23 pm
Out with the old in with the new!!
Cut off!!
PostPosted: Sat Jan 23, 2010 2:28 pm
Got some more work done
PostPosted: Thu Feb 04, 2010 12:41 pm
So finished the frame and now trying to plan the z. I want to keep the motor in so any insight would be appreciated!!!
PostPosted: Thu Feb 04, 2010 10:37 pm
Me and a friend did my Z with the engine in, and it only took about 2 hours. I made my cut about. 8 inches in front of the firewall. You will wanna mark it and then cut the marks in with a grinder. Make sure to make your cut straight up and down or it will line up funny. I did mine 1.5 inches. I didn't Z the front of the frame. I cut out the crossmember on the radiator support that is right under the radiator, and the I sectioned the 2 mounts 1.5 inches. You will have to cut the radiator support first or thee frame will not line up. I layed my truck out on 4x4's and used a floor jack to raise the front clip. And then weld it all together.
PostPosted: Thu Feb 04, 2010 11:10 pm
Do u have any pics of your work?
PostPosted: Thu Feb 04, 2010 11:36 pm
No, I always forget to take pics. Sorry.
PostPosted: Sun Feb 07, 2010 9:01 pm
So did the z and was a little hesitant. Will post pics tomorrow!!!
PostPosted: Mon Feb 08, 2010 8:00 pm
New crossmember!!
And then the Z!!
PostPosted: Mon Feb 15, 2010 2:17 pm
Finally on the ground!!!
PostPosted: Mon Feb 15, 2010 9:30 pm
Very nice 8)
2006 GMC Sierra 2500 HD
PostPosted: Sat Feb 20, 2010 12:33 pm
I'm not very knowledgable in the fabrication area. I have a 1979 that I cranked out the torsion bars to lower it down a bit. It looks like the wheels will hit the fenders if I go any lower. How did you get your wheels to tuck in the fenders?
PostPosted: Sun Feb 28, 2010 9:54 am
Its probably the offset of the wheel your running. The rear of the truck is more of a rwd offset and the front to tuck u need more of a 0 offset. I'm running steel wheeld off of a hardbody. Any steel 6 lug for a smaller truck will work. Now I have my own issue I need some help with the steering column. What size is it so I can put a u joint on it to go into the steering box?
PostPosted: Sun Feb 28, 2010 7:17 pm
why do you z the frame just curious
PostPosted: Sun Feb 28, 2010 8:40 pm
LSX LUV Owner
B.Luv, thats how my truck was when i cranked the bars. it is probably the shims on the UCA. pull them out and the wheel should camber in enough to clear. but will suck for driving.
PostPosted: Mon Mar 01, 2010 2:54 pm
IM realy liking your truck. I luv the way it looks right now! and with those wheels. those are off a yota?
1975 luv daily driver.
Project-soon to be revived
PostPosted: Mon Mar 01, 2010 3:09 pm
never mind on the wheels, looked back and saw that there were of a hardbody. sorry :D
PostPosted: Mon Mar 01, 2010 3:22 pm
Yea there just stock steel wheels but I bought early 70's chevy hubcaps for them once its ready. And to answer that other question you have to Z the frame because of the front crossmember under the engine sits lower than the frame. If you do not z the frame it will not lay flat on the ground.
PostPosted: Mon Mar 01, 2010 4:37 pm
didnt z mine and it lays flat out..
Epic Fabrication.
KAOS
