It is currently Sat Mar 28, 2026 12:14 pm
 Post subject: Radiator Replacement
PostPosted: Sun Jan 10, 2010 4:51 pm
Does anyone have a good radiator they would like to sell? I've searched radiator on this forum and have come to the conclusion that they are real hard to find. Is there an alternative radiator that can be modified to fit?
 Post subject: Re: Radiator Replacement
PostPosted: Sun Jan 10, 2010 6:16 pm
Are your tanks usable? A rad shop can re core yours if you can't find a new one.
PostPosted: Sun Jan 10, 2010 7:04 pm
I have two radiators. The one in the truck doesnt leak but the cooling fins are really brittle and almost just crumble when you touch them. Another that I have has a pin hole leak in the center of the radiator. There is a radiator shop a couple blocks from my house I will check it out. Thanks for the info.
PostPosted: Mon Jan 11, 2010 12:02 am
Australian LUV Guru
Spend the little extra and have a 3row core fitted to your stock tanks.
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Mon Jan 11, 2010 11:09 pm
Yes, thank you. I should have said that. I had it done to one of mine. :roll:
PostPosted: Mon Jan 11, 2010 11:43 pm
if you really need i came across this today:
http://boise.craigslist.org/pts/1546788189.html
Dont know the guy or if what he has is any good
PostPosted: Tue Jan 12, 2010 12:12 am
Australian LUV Guru
48 degrees celcius here in my part of Australia today, im glad i have a 3core rad in my truck.
