It is currently Fri May 01, 2026 5:10 am
Post new topic Reply to topic  [ 73 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: EJ20 LUV
PostPosted: Thu Sep 17, 2009 7:25 pm
Codym wrote:
I have do more of the wiring but it just looks like a bigger mess than what I started with. :?
Wow! That is a crazy number of wires. Good luck.
Eric Q.
My build thread.
PostPosted: Sat Sep 19, 2009 2:31 pm
Well I have about 25hrs into the wiring. Most of it is research and double checking. I don't really know what I'm doing so I'm taking my time. Still need to cut more out
What I THINK I don't need
What is left so far
PostPosted: Sat Sep 19, 2009 3:16 pm
I've been following this thread. Man I can't believe the wiring you have to do. That alone wouls steer me in a different direction...no patience. Can't wait to see the end result.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Sat Sep 19, 2009 7:20 pm
Mmmmm......spaghetti!! :P
PostPosted: Sun Sep 20, 2009 4:05 pm
dont give up. sometime you have to go through a few headacks to do something no one else has done. but keep it up. i got some subaru guys all freaked out about your luv :lol: . but i cant wait to see more progress on this. after seeing this build and all the confusing wires, made me want to join in on the fun in messing with the wires as well. so im going to which to fuel injection on my project. i think? :? . but still wont be as cool as yours. keep it up. and have fun with all that. just remember ITS EASY. :lol:
1975 luv daily driver.
Project-soon to be revived
PostPosted: Wed Sep 23, 2009 2:36 pm
I agree with the other guys... Keep making progress on this build. At first I was only mildly interested in this build but I've found myself thinking about how cool this could be everytime a subaru passes me. I hope you eventually get the all wheel drive functional too. That would be soo cool.
Anyhow, keep up the good work. Good luck. Looks good. What ever else I need to say to keep you motivated. :lol:
Eric Q.
My build thread.
PostPosted: Fri Sep 25, 2009 12:23 am
Wow thank you for all of the word of encouragement. This project is taking a little long than I had planned and a lot more money 8O but you guy are definitely keeping me going.
I have been working a lot of over time so I haven't had to much time to work on it but now I do have some money to spend on parts. It looks like work is starting to slow down so hope to have some good updates in the next few weeks.
PostPosted: Tue Oct 06, 2009 2:13 pm
so whats the progress on this bad boy. did you get much done with the engine?
PostPosted: Wed Nov 18, 2009 1:27 am
Sorry no real updates I have still been doing a lot of OT at work and have been doing more research on the wiring.
I did finish up on my daily drive this last week.
I have a 05 WRX Wagon with a lot less work done to the motor than what I have planned for the truck. I got 281WHP and 260TQ on daily drive tune.
I'm taking a 2 week road trip south this weekend but when I return it is balls out on the truck.
PostPosted: Wed Nov 18, 2009 6:40 pm
:esurprised i luv the wagon. and thats cool that you drive a subaru too. as you can see i like subaru :D . ok look forward to the up and coming progress of ej20 luv. :? WAIT! am i looking more forward to your project then mine :esad. I need to come up on some money and fast. :lol:
PostPosted: Thu Nov 19, 2009 3:33 am
Subarus are the stuff... always been a fan of the H-4. The possibilities of a turbocharger and FI with AWD in a LUV just... I dunno. Freakin' Sweet!
PostPosted: Tue Dec 22, 2009 5:02 pm
So I haven't really work on it in a while but still looking for parts here and there. I picked up some cams. Duration is the same but the lift is higher. Should start on heads and then complete the long block the first of the year. Then I can start to sqeeze it in.
PostPosted: Tue Dec 29, 2009 9:38 am
please excuse my ignorance. but why did you un-loom the wiring. the engine harness will route on the motor the same way. are you using the complete harness for the entire truck? its an awsome build cant wait to here about it on the road.
not knocking the guys with the V8's but i just got done with my sr20 turbo and 11psi boost. this truck is retarded quick and passing on the freeway is like butter. plus with a 4cyl you get to keep the nimble handling of these trucks.
recently purchased 72 luv truck
1970 dodge charger- 500ci 5 speed
ram big horn 5.7 hemi
PostPosted: Wed Dec 30, 2009 1:40 am
There are a lot of wires that I don't need to run the engine and that is all the wiring I'm going to use. Some of the wire that I have taken out are Keyless entre, ABS, Airbags, TGV's and more.
PostPosted: Wed Dec 30, 2009 12:59 pm
cool..
i cheated and just folded the wires i didnt need into the harness. but i only used the engine harness and ecu. although i do have pins for the instrumentation and check engine light
PostPosted: Thu Jan 21, 2010 9:54 am
any updates
PostPosted: Wed Mar 31, 2010 10:50 pm
whats up. hows the project coming along. any new updates of any kind. :D
PostPosted: Fri Apr 02, 2010 1:04 pm
Well not to much. The wiring is done till I get them motor in. I picked up some cams that I needed to plug some holes. I got the heads cleaned up and as soon as the outside temps come up a little I will put the heads on.
But all in all not much. But I have been saving some money up so as soon as it warms up it should go fast.
PostPosted: Wed May 12, 2010 12:36 pm
Started to biuld out the motor yesterday. These motors still look fun to me.
Today I will be putting the new cams in and getting the gapping right.
PostPosted: Thu May 13, 2010 6:48 pm
now that is a badass swap,
i have considered alot of different engine swaps but that is by far the best i have heard so far! how much has that setup run you so far??
well how much was the engine and transmission combo alone?
