It is currently Mon Jun 08, 2026 3:56 am
 Post subject: Spark knock?
PostPosted: Mon Dec 14, 2009 11:49 pm
Hey all I have a 76 that I bought last month and have been driving it back and fourth to work and the other day while on the freeway just all of a sudden stated makin a spark knock sound. It stated loosing power on the way home but thankfully I made it. I checked timing its at 6 degrees btdc replaced vacuum line to distributor, put in new points, cap, rotor, condensor, spark plugs and played with carb quite a bit to no avail. its still making the spark knock like its got really bad gas in it or its out of time. I had a 75 bronco that blew a head gasket between 2 cylinders and did this same sort of thing so Im hopin that isnt it and maybe you guys could point me in the right direction. Thanks! :ebiggrin
 Post subject: Re: Spark knock?
PostPosted: Tue Dec 15, 2009 1:31 am
Uh, that really sounds like a blown head gasket. That's not a huge operation, nothing to be afraid of. You could start by doing a power balance test. To do that, you'll need a long needle (preferrably an embroidery one), a section of wire, and a place you know has a good ground. Start the truck, and one at a time, stuff the needle with the wire solidly attached to both the needle and a good ground, into the sparkplug boot. Listen to the engine. An RPM drop when you ground out each cylinder is a good thing. If you ground out a cyl, and the RPM doesn't change, it means that cyl is producing zero power, and has a serious problem. If two ajacent cyls. put out no power, there's a good chance that you have a blown headgasket between the two cylinders. If it's only one cylinder, check for spark and compression.
The same thing happened to me. Started making a loud whap whap noise, and it turns out that I had blown the headgasket between my #3 and #4 cylinders.
If you need help with the changing the head gasket, Figuarus just fooled around with his, and I think he's got it down to a science. :wink:
Good luck and welcome to the site!
-Ret
PostPosted: Tue Dec 15, 2009 3:20 am
hehe why thank you kind sir! :lol:
If you need help, look up the thread for "blown head gasket?"
I also have pictures and procedures written down that are alot more clearer than the chilton or haynes manual offers. Did i mention i have pictures?
PostPosted: Thu Dec 17, 2009 12:29 am
ok thanks for the input! I will try grounding out each cylinder this weekend. I drive truck for a living and wont be back home till then. Ive done a few head gaskets before but always on small block ford or mopar. this shouldent be too much different just half the work right!!! Ill take a look at that thread also. If Im not mistaken I believe it was mention there was pics. :D
PostPosted: Thu Dec 17, 2009 4:20 am
indeed there are. i will have to upload them soon.... i had to move them. look out for a new post
PostPosted: Mon Dec 21, 2009 7:41 pm
Hey all, just an update. I finnished up with the head gasket today. That wasnt too bad at all! it was blown between the no. 1 and 2 cylinders. Thank you all for the great advice and pics. the zip ties on the timing gear was a life saver. now to get on with fixin her up! :D
PostPosted: Mon Dec 21, 2009 8:23 pm
glad it worked out! didja fire her up already?
PostPosted: Sat Dec 26, 2009 7:50 pm
yep fired her up and she runs like a champ! drove her around all week and runs great. thanx again.
PostPosted: Sat Dec 26, 2009 7:56 pm
glad to hear it's back where it belongs: on the road! :lol:
Users browsing this forum: Bing [Bot] and 41 guests
