It is currently Mon May 25, 2026 11:17 pm
 Post subject: 2" lift? and shocks???
PostPosted: Sat Dec 19, 2009 3:55 am
i got a performance accessories 2" lift kit for 79-80 4wd luv and wondering if i need anything else to put it on?
also i put gas charged shock absorbers on front to replace the old ones and got air shocks in the back. what would be the best setup for those?
1980 chevy luv 4x4
PostPosted: Sat Dec 19, 2009 5:56 am
I have tried air shocks twice years ago and didn't have good results either time. I'm sure technology has come a long way since then but this is just my two cents worth...I wouldn't install them on anything I own that I intend to use as a daily driver and also a "play" truck. I'm sure there are people out here that can contradict what I'm saying with better results but personally I wouldn't install them. As far as the rest of the kit, there should be some sort of instructions with it...I have done many, they usually aren't that hard to install.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Sat Dec 19, 2009 12:22 pm
ok thank you
1980 chevy luv 4x4
