It is currently Mon Jun 08, 2026 1:33 am
 Post subject: carb whoops
PostPosted: Tue Dec 15, 2009 10:11 am
so i just got the vachum leak fixed but i turned the carb upside down to scrape the gasket and the slide out thing in the venture that lets the fuel out fell out into a big bucket of anti freeze. i found it cleaned it and reinstalled. problem is that it sits kinda loose and the other side appears to have a small shim of some kind between it and the venturi wall. all is well till i give the skinny pedle hell then it bogs. so i know it is leaking fuel. does any one know how to remidy this or where to buy a new one. the other option is this weber available to me for 100bucks factory rebuilt. is this the one ideal for the luvs. he said it was a 32 36 but i know there was other variables. thanks
File comment: weber 3
File comment: weber2
File comment: weber 1
do everything in you life so you can put your name on it
 Post subject: Re: carb whoops
PostPosted: Tue Dec 15, 2009 5:15 pm
That's a 32/36 DFEV (Same as the Holley 5200), it's a mirror image of the Weber 32/36 DGEV, and I think you'll have to work harder to bolt that one on. Means the primary and secondary are opposite and so I think the fuel line and accelerator linkage will come out in the wrong spot. Ideally you want the DGEV.
PostPosted: Wed Dec 16, 2009 12:22 am
i was affraid of that. oh well. looks like im fixing the stocker till spring. any ideas on the "retention plate" or what ever it is
PostPosted: Thu Dec 17, 2009 9:46 pm
does any body have a parts car b willing to sell me this piece?
Users browsing this forum: No registered users and 61 guests
