It is currently Sun Jul 05, 2026 11:07 am
 Post subject: Weber questions
PostPosted: Thu Dec 10, 2009 11:27 am
ok, here's the story...my truck was sitting for about 3 years and i finally started working on it. i had to replace the head and i cleaned out the carb (Weber) and changed all the fluids and put fresh gas in it. when i tried to start it it was having major issues. the valve timing was off and i corrected it same with ignition. after fixing those it started right up. it ran very smoothly for about a minute then shut off and i cant get it started again. i have spark, points gap are good (btw, i replaced the whole ignition system except the coil), but the only thing that i am noticing is that after trying to start it, i look in the carb and see fuel still pouring into it. is something stuck open? can anyone help?
 Post subject: Re: Weber questions
PostPosted: Thu Dec 10, 2009 2:20 pm
sound like the float is stuck open... did you clean the car or rebuild it? rebuild kits are only about $30 and come with new plunger for the floats and o ring
