It is currently Sun Apr 05, 2026 6:53 am
 Post subject: questions on ohms law?
PostPosted: Wed Dec 09, 2009 11:47 am
i need help. if anyone could explain to me how this works i would greatly appreciate it
What is the relationship between Resistance & Amperage?
and
What is the relationship between Resistance & Voltage?
i just dont see how there is a relationship... of course im 18 and don't understand much, but it would be great to have an insight on the subject
Thank you
80 Chevy LUV 4x4
PostPosted: Wed Dec 09, 2009 12:19 pm
This is a good explanation. It seemed a little hard at first when I was going to school.
http://www.allaboutcircuits.com/vol_1/chpt_2/1.html
http://phet.colorado.edu/simulations/sims.php?sim=Ohms_Law
That one is cool.
Another one.
http://www.angelfire.com/pa/baconbacon/page2.html
Play around with the values and see what happens.
I am not sure how to explain it. Our problem with instructors was they already knew it and did not know what we didn't understand... When one of us figured it out, we could help the others.
PostPosted: Wed Dec 09, 2009 12:22 pm
Thank you. That was really helpful, and that is how it is in school. we have to wait till one of the other students can figure out an easier way of explaining it :lol:
80 Chevy LUV 4x4
PostPosted: Wed Dec 09, 2009 12:24 pm
18 doesn't matter, I was 35 when I "learn't"it :oops:
PostPosted: Wed Dec 09, 2009 12:38 pm
well im good on everything else, jsut the damn electrical ohms law stuff :(
80 Chevy LUV 4x4
PostPosted: Wed Dec 09, 2009 1:59 pm
And just in case you think the need to know doesn't matter, I recently took a test for a job and 4 questions pertained to Ohm's law...
PostPosted: Wed Dec 09, 2009 4:04 pm
I kinda like this one, if you can manage to remember this symbol.
http://www.autoshop101.com/trainmodules ... rc109.html
My memory works off of pictures, or mental snapshots, so I can remember stuff like this easier than text.
PostPosted: Wed Dec 09, 2009 5:07 pm
If you are still struggling, think about all the stuff in your house. Most of the wiring has about 120 volts. Your toaster has a fairly low resistance and the voltage will push 5-10 amps through it. A compact flouresent light has a very high resistance and the voltage may only be able to push less than a tenth of an amp through it.
Many things need very high power and run on 240 volts, dryers, water heaters, A/C, etc. The higher voltage pushes more amps through the same resistance.
PostPosted: Wed Dec 09, 2009 7:48 pm
I'm 52 and all I know is that electricity friggin' hurts! 8O
Rick
Loranger, La
1980 Stepside LUV (Again)
PostPosted: Thu Dec 10, 2009 9:11 am
:signiagree I feel 12 volts too, just laying my arm across a car battery.
PostPosted: Thu Dec 10, 2009 9:46 am
Ben
That is a good one!!! I don't know why the don't teach it like that.
PostPosted: Thu Dec 10, 2009 2:22 pm
thats how my teacher is teaching me but its a little confusing at first. and yeah i learned from stupidity that electricity hurts, i was taking off my distributor cap to fix the rotor and i forgot to disconnect that negative battery cable..... youcan already see were this is going :(
thanks everyone for the help
80 Chevy LUV 4x4
