It is currently Mon May 25, 2026 10:58 am
PostPosted: Sat Dec 05, 2009 1:59 pm
Can any one help me on giving me tips o how to put a 200 4r transmission on a 1977 LUV?
PostPosted: Sat Dec 05, 2009 2:56 pm
A 2004R wont swap to a standard LUV engine, if you have swapped to a more common GM engine then it might be applicable.
A.j.
PostPosted: Sat Dec 05, 2009 9:16 pm
im going to convert the luv to a v8 .im going to put in a chevy 355 with the 200 4r transmission but i researched that the 200 4r has the mounting holes 6.5 inches more back than the 700r4 0r 350 I just wanted to know if that is not going to be that bad of a problem?
PostPosted: Sun Dec 06, 2009 10:14 am
Why not just go with a 700? Is the 200 a better trans?
PostPosted: Sun Dec 06, 2009 10:53 am
Yes...
PostPosted: Sun Dec 06, 2009 1:46 pm
i already have the transmission and I don’t want buy another one that’s why, and i like the 200 4r because it has four gears and overdrive
PostPosted: Sun Dec 06, 2009 4:05 pm
http://www.transmissionadapters.com/transmissions.htm
PostPosted: Mon Mar 22, 2010 4:08 pm
what makes the 200 better than the 700?
i planned on using a 700r4. but my build is a bone stock 305 sbc. wont be racing. just driving. i was after the OD is why i picked 700r4 in the first place
PostPosted: Tue Mar 23, 2010 12:51 pm
http://www.webrodder.com/article.php?AID=426&SID=6
Both will work. Your long term plans might make the difference.
PostPosted: Tue Mar 23, 2010 3:08 pm
gear ratios for the 200r4 are more appealing if you are just doing normal driving.
ratios are
1st: 2.74
2nd: 1.57
3rd: 1.00
4th: .67
PostPosted: Tue Mar 23, 2010 6:50 pm
TH-200-4R..........2.741 1.568 1.000 0.674 2.067
TH-300 (Jetaway)
TH-350...............2.52 1.52 1.00 ---
TH-400 (3L80)......2.482 1.482 1.000 --- 2.077
TH-700-R4 (4L60)..3.059 1.625 1.000 0.696 2.294
4L30-E................2.400 1.479 1.000 0.723 2.000
4L30-E Optional....2.860 1.620 1.000 0.723 2.000
4L60-E................3.059 1.625 1.000 0.696 2.294
4L60-E Optional....3.080 1.880 1.000 0.790
PostPosted: Tue Mar 23, 2010 6:58 pm
long term is the same as now. if i ever go bigger id be taking out the 305 anyway and would change the whole setup
Users browsing this forum: Bing [Bot] and 17 guests
