It is currently Fri Jan 30, 2026 9:16 am
Post new topic Reply to topic  [ 56 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: 78 DedicateD luv
PostPosted: Wed Nov 18, 2009 10:44 pm
dr_frankenstein56 wrote:
chevyluv1980 wrote:
All I have to say is your son is a spittin' image of you! :lol: :lol:
Also, another step by step buils with pics for everyone get into.
Hey Ben, how about a new section for non LUV builds by LUV owners? I can post my 53 Ford F-100 I will start on in January.
I think thats a Fantastic Idea!
Id love to show some of the new race motors we got coming out!
A.j.
That would be the Lounge section...
PostPosted: Thu Nov 19, 2009 3:26 am
1953 Ford... That's the truck that my dad's been after rebuilding for so many years. Had it most of the way done, and then the shop burnt down around it... Everything but the cab burned, so it's still salvageable, but been quite the setback.
I'd really like to see one of those trucks finally being put together, so I'll watch your thread if you post one chevyluv1980.
PostPosted: Thu Nov 19, 2009 4:05 pm
I kept mine 6 lug, have an s10 rear, had the hubs and axles drilled to 6lug. Everyone changes theirs to 5lug, wanted to be even more different, lol
PostPosted: Thu Nov 19, 2009 5:50 pm
Well I'm doin 5 lug for ease. Since I'm gonna be running s-10 front spindles and have a s-10 rear end sitting around my buddy gave me.
DedicateD Ashland Chapter
PostPosted: Thu Nov 19, 2009 7:33 pm
The LUVlounge is for kicking back and relaxing. Besides, were trying to keep Ben gainfully employed! Guess I need to find the pics of adapting a Chevy 700R4 tranny to a small block Ford 302.
Rick
Loranger, La
1980 Stepside LUV (Again)
PostPosted: Thu Nov 19, 2009 7:42 pm
Check out rangerpowersports.com there was a guy on there who adapted a 700r to a sbf
PostPosted: Thu Nov 19, 2009 8:35 pm
http://www.700r4inaford.com
1975 luv daily driver.
Project-soon to be revived
PostPosted: Fri Nov 20, 2009 12:41 am
one more thing if you do decide to for sure run the 700r4 make sure you buy and aftermarket reaction shell, that is the most common spot to fail on those transmissions, ive changed shells already. 4l60e is also bad about the shells going bad. you loose 2nd overdrive and reverse when they shear or strip. ive seen one strip the rest have sheared.
PostPosted: Fri Nov 20, 2009 10:22 am
What is a reaction shell? I saw those kits and they are pricey. My tranny hook up was under $50 and did require using a lathe for a new torque converter button.
Rick
Loranger, La
PostPosted: Fri Nov 20, 2009 9:07 pm
The reaction shell is also refered to as the sun gear or planatary. It's casing is really thin on the factory ones. It's the most common fail point on those trans.
PostPosted: Fri Nov 20, 2009 9:16 pm
Crap. I had the tranny rebuilt while I was in Las Vegas and wish I had known then. It has yet to be used. What is the difficulty changing it myself?
Rick
Loranger, La
PostPosted: Sat Nov 21, 2009 12:04 am
well basic tools except a torx plus size 50 i think, a reagular torx bit will strip them out. the first time i did it i read a how to article i found from google. if you just had it rebuilt i wouldnt worry about it unless you plan on alot of power. its a common problem on internals with over a 100k usually. i just assumed you was using a used one. a transmission rebuilder would be fimaliar with the 700r's problems and would have checked it out. im not a transmission man by anymeans, im just stobborn and refuse to pay 2500 for a rebuild, so i learned the hard way of how to do it. ill try any thing mechanical at least once before i pay to have it done.
PostPosted: Sat Nov 21, 2009 11:02 am
Don't plan on LOTS of power, but would eventually like to hit 250 hp. Maybe 300! Thanks for the info.
Rick
Loranger, La
PostPosted: Sat Nov 21, 2009 4:12 pm
Yea. I'd say it would hold 325 350 with out a problem.
PostPosted: Sat Nov 21, 2009 10:37 pm
Done any work to the Luv yet?
2006 GMC Sierra 2500 HD
PostPosted: Sun Nov 22, 2009 8:56 am
Not yet besides working on the fuel system.
PostPosted: Wed Nov 25, 2009 9:50 am
Ordered my fuel cell, and new fuel pump to get her running again. And Friday my 4 link order is being placed.
PostPosted: Wed Nov 25, 2009 10:55 am
What fuel cell and pump are you going to install? Also, where will you put the fuell cell?
Rick
Loranger, La
PostPosted: Thu Nov 26, 2009 5:00 pm
I ordered summit brand drag cell. It's a 12 gallon bottom sump. And an inline Carter pump that is a replacement for the 1.8 luv. All from summit. And I'm mounting the cell in the bed against the cab.
PostPosted: Mon Nov 30, 2009 7:03 pm
Well guys it didn't go as planned this past weekend. Didn't get it home. I forgot to order the two an 8 fittings to plumb my cell up. And no part store around here has even heard of them lol. And now getting the fittings will be delayed another 2 weeks because I had a blow out on my daily blazer Sunday morning. So I'll update with new pics and it in my garage in two weeks. Damn this sucks.
