It is currently Wed May 06, 2026 2:49 pm
 Post subject: 4x4 popping out
PostPosted: Mon Nov 16, 2009 7:24 am
ok my 1980 chevy luv 4x4 has good power when its in 4x4 drive. the only problem is sometimes i have to hold the shifter down so it wont "pop out of gear". what could be the cause of this? this is my first 4x4 :D
Thank you
80 Chevy LUV 4x4
 Post subject: Re: 4x4 popping out
PostPosted: Tue Nov 17, 2009 9:05 pm
There is a spring that goes around the 4x shifter to a bracket on the tranny that holds it in 4hi. It prolly just broke off, not sure where you can pick one up
PostPosted: Wed Nov 18, 2009 11:33 am
ok thanks i will look under it when i have the time.
80 Chevy LUV 4x4
PostPosted: Wed Nov 18, 2009 11:13 pm
Yea, it's just under the boot. Mine was missing when I got the truck, and I had the same problem.
PostPosted: Thu Nov 19, 2009 10:34 pm
well mines there and its good. i think it could be in the transfer case which i hope its not =[. I may try to shorten the shift linkage to see if that helps a little. any suggestions?
80 Chevy LUV 4x4
PostPosted: Sat Nov 21, 2009 4:09 pm
Is it a stock 4x4? Just a shot in the dark, does it have a body lift on it? If it does, that can cause the shifter to not engage completely because the hole has moved.
If it's stock, and the spring is there, then it may be something internal.
PostPosted: Sat Nov 21, 2009 6:13 pm
Mine would walk out of 4 hi with the hubs locked. With them unlocked, it would stay in 4 hi. It was missing the spring. It works fine now.
Have you tried it with the hubs unlocked?
PostPosted: Sat Nov 21, 2009 7:14 pm
its stock, no lift. and yes i believe it is something internal.
thanks for the help :smt023
80 Chevy LUV 4x4
PostPosted: Sat Nov 21, 2009 7:17 pm
I have'nt tryed it with them in the "free" position but i always thought that it wouldnt work if it wasnt locked.
80 Chevy LUV 4x4
PostPosted: Sun Nov 22, 2009 1:58 am
With the hubs in "free", and the case in 4 hi or low, the front shaft will turn with the case, but not deliver and power to the front wheels because they are not locked. Make sense? So yes, it's useless to run this way.
Although, I will use 4 low, unlocked, sometimes to utilize the low gears/speed/power, when 2wd is good enough but torque at a low speed is needed.
PostPosted: Sun Nov 22, 2009 7:31 pm
My after market boot puts just enough pressure on the shifter to push it out of 4 hi. But I have a body lift too.
PostPosted: Tue Nov 24, 2009 4:36 pm
its the same MSG trans as mine just not a 5 speed....
the spring is streched more in 2WD mode than in 4 HI and LO
and sence the auto spends more time in 2WD the spring is streched over the years.
thus theres less pull with the older spring.
the only places i know of that can get the spring new are.....
the very few isuzu auto dealers that have contenued to sell origanal isuzu parts and......
Jerry over on the isuzupup.com site, he has a lisense to sell origanal spec isuzu parts.
for about 10%~ over his cost, he lives in Georgia.
hes retierd from the isuzu corp he was a USA isuzu auto trainer.
what ever your queston, he will have a answer :!:
86trooperT/D 2.2
84 L\B 4x4Diesel LS 2.2
86 L\B 4X4 gas 5 speed 2.3
