It is currently Sun Jun 07, 2026 6:37 am
 Post subject: wheels
PostPosted: Sun Aug 31, 2003 11:31 am
HAS ANYBODY TRIED TO PUT NEWER 90-03 STOCK CHEVY,GM,TOYOTA,NISSAN WHEELS ON A LUV?
PostPosted: Mon Sep 01, 2003 2:00 pm
toyota and nissan rims will fit. but i think the rest will to but im not sure about that. matt
PostPosted: Mon Sep 01, 2003 3:56 pm
All 6 lug rims have the same bolt pattern, I'm runnig chev rims on my nissan, and if nissan will fit LUV, which they will, chev will too. and 6 lug jeep rims too
PostPosted: Mon Sep 01, 2003 4:42 pm
The only problem you may incounter will be the center hole diameter. I ran into this problem with one of my deals but cant remember what I was swapping around..
Spanky
GOTTA GET A NEW LUV!!!!!!!!!
PostPosted: Mon Sep 01, 2003 5:06 pm
i think most newer chevy rims are 16"ers. other than that thier still 6on 5.5.
PostPosted: Mon Sep 01, 2003 9:37 pm
yes the 6 hole will fit but will the back spacing be good? (offset)
