It is currently Wed Mar 18, 2026 1:38 am
Post new topic Reply to topic  [ 330 posts ]  Go to page Previous  1 ... 11, 12, 13, 14, 15, 16, 17  Next
PostPosted: Tue Nov 03, 2009 7:52 pm
PM sent. they should be in transit right now. The guy with the drag truck should be getting back to me soon. then we will know how well those fit.
shawny b has toyota spindles and his have positive camber. Im gonna have to shorten his uppers to make it right. The S-10 spindle is closer to the LUV than the Toyota so you guys that need to make that choice should lean toward the S-10 unless you are running coilovers. bag guys definitely will benefit from the travel of S-10 over toyota spindles. travel wont change but camber thru the travel will change more with Toyota spindles due to the uppers being shorter.
Michael White
www.dallashotrodparts.com
PostPosted: Wed Nov 04, 2009 3:37 pm
just want to know is the knuckle off a 2000 blazer is the same for all s10 and blazer from 1983 and up. cuz I would like to use the knuckle that has a hub and not the spindle.
1975 luv daily driver.
Project-soon to be revived
PostPosted: Wed Nov 04, 2009 7:09 pm
No...
PostPosted: Thu Nov 05, 2009 12:30 pm
what do you mean "knuckle"? dont know of any auto part called that..
Michael White
PostPosted: Thu Nov 05, 2009 3:04 pm
Pretty sure he means spindle.
PostPosted: Fri Nov 06, 2009 2:04 am
the correct trem is knuckle, or steering knuckle. then there is the spindle that is pressed or cast with the knuckle. its just every one knows it by spindle I too call it spindle sometimes. its like, the cresent rentch and monkey rentch (sorry dont know if im spelling it right). but those are not the correct names of them but yet we still use it. so spindle, knuckle its the same thing.
PostPosted: Fri Nov 06, 2009 4:12 pm
well I will finally be able to assemble Mightymouzs lowers. The uppers are close. I have the balljoint cups, bushing sleeves and all the pieces cut and already have the K772 screw in balljoints.
On another note Im making Kyle some lowers with more drop built in so he doesnt have to notch the frame so much.
Michael White
PostPosted: Fri Nov 06, 2009 6:32 pm
Thanks for the update... 8)
PostPosted: Mon Nov 09, 2009 12:06 am
hey mike you alta have my original ones their some time this week..hows the time frame on my new onesw looking????
Epic Fabrication.
KAOS
PostPosted: Mon Nov 09, 2009 5:45 am
good kyle. I went to shawnybs yesterday and for the most part everything looks swell. the toyota spindle is way different than an S-10 spindle but should be ok. a drop spindle would certainly help with more room for a bag though.
Michael White
PostPosted: Mon Nov 09, 2009 5:13 pm
yeah i have 2in drop spindles
Epic Fabrication.
KAOS
PostPosted: Fri Nov 13, 2009 6:54 am
whats the setup being used that requires notching the frame? just so i know ahead of time if i have to do it or not
PostPosted: Fri Nov 13, 2009 4:15 pm
That would be the bag version. the notching is only above the rear tube and its not alot. If I make them an inch or so narrower and add in some more drop I may be able to eliminate the need to notch the frame. Im making some lowers now that are dropped a bit more than the last version and we shall see what happens there.
updates to come.
Michael White
PostPosted: Fri Nov 13, 2009 5:54 pm
updates to come.
thanks mike. its still a month or so until i can order mine anyway. maybe it will be cleared up by then. will you need any of my stock suspension parts for future use?
PostPosted: Sat Nov 14, 2009 7:55 am
naaa, I wont need any of that.
Michael White
PostPosted: Sat Nov 14, 2009 2:07 pm
just checking
PostPosted: Wed Nov 25, 2009 10:22 pm
Anything new?
PostPosted: Fri Nov 27, 2009 7:31 pm
have you got my lowers sent out yet..
Epic Fabrication.
KAOS
PostPosted: Mon Nov 30, 2009 7:27 pm
Mike, I am coming in on this thread kinda late but your A arms are what I need for my project truck. I would like to order a set of uppers and lowers, the narrowed version for a S 10 spindle, using coil-overs. What do I need to do to order them? Do I need to place the order on your website? Your work looks great and thanks for taking the time to help us out and fill a need on our trucks. Steve
PostPosted: Mon Dec 07, 2009 8:42 pm
Im guessing you just ordered some the other day. anyway Im working on some now. Kyle heres your tracking number in case you cant get to your email..1ZX761920373759443
Michael White
