It is currently Thu Feb 19, 2026 11:58 am
 Post subject: ARGH!!!!
PostPosted: Tue Nov 03, 2009 12:28 am
:evil: im not feeling any love towards my luv....... everyteim i turn around somethings not right with it all i wanted to do is change the head gasket now its a full on escapade. i have no idea what to do other than pull; the whole motor and start over ....... it wont turn on. back fires in the carb. i thought i did it per the book but idk..... thank god for my family whos nice enough to switch cars while im doing all this....
75-luv mikado-V8 350 soon
 Post subject: Re: ARGH!!!!
PostPosted: Tue Nov 03, 2009 12:30 am
Sounds like a timing problem?
PostPosted: Tue Nov 03, 2009 12:34 am
yep thats what i think but i turn the distributor and it does the same thing ....
PostPosted: Tue Nov 03, 2009 12:54 am
Do you maybe have it 180 degrees out?
Just to be sure you had it at TDC when you put the distributor in correct?
PostPosted: Tue Nov 03, 2009 1:04 am
it can only sit in the slot in the oil pump drive shaft thing one way and i did it like the book says so..
PostPosted: Tue Nov 03, 2009 1:19 am
Could there be even the slightest chance that the valve timing is off? Always go back to the last thing you did before it started running like hell... and since you changed the headgasket, that's always a possibility.
PostPosted: Tue Nov 03, 2009 8:09 pm
Classic symtem of valve timing 180 out. Double check----Turn engine till ignition timing mark is at zero, check that distributor rotor points to #4 cylinder, check that the line on the camshaft (behind the sprocket) lines up with the one on the rocker bracket, should be strait up. If not there's the problem.
Sounds dumb I know, but make sure the plug wire fireing order is correct.
PostPosted: Tue Nov 03, 2009 9:49 pm
Are you sure you put the sparkplug wires on the dist. cap correctly.
On my old boat I had the rotation of the dist. wrong. It was clock wise not counter clock wise, or whatever. It let out a few big pops untill I figured out I had done.
PostPosted: Tue Nov 03, 2009 10:11 pm
ya I agree with everyone else on this one. luv75/77 I feel your hatered on this one though my truck hasnt been much of a problem. my spark plug was heli coil and I didnt know. so when I pulled out the spark to change it, so did the heli coil :lol: . so it over sized now :( and I just keep jb welding it cuz i dont want to pull the head 8O but waiting till I have the much awaited problems like every one else.
1975 luv daily driver.
Project-soon to be revived
