It is currently Sun Jun 07, 2026 12:20 pm
 Post subject: performance cam
PostPosted: Tue Aug 26, 2003 8:57 pm
I am new to the web site and think it is great. The question I have is that I am switching motors in my 79 4x4. I would like to get a bigger cam for it. does anyone know where I can order one. Also I wouldlike to upgrade to electronic ignition instead of the points. does any company make this or is there a swap that I can make.
PostPosted: Tue Aug 26, 2003 9:08 pm
Welcome to the site!! I dont know much about the stoke trucks but we deal a lot with Comp cams at work and I think they would be able to help you in that field. as for the electronic aspect you may look into Pertronix ... I dont know if they fit or make a kit for a stock truck but may be worth a try...
Later Spanky
GOTTA GET A NEW LUV!!!!!!!!!
PostPosted: Wed Aug 27, 2003 8:12 pm
Thank for reply. Unfortunatly todayI called crane cams and edelbrock and they said they have nothing for a 79 chevy luv. Unless i got some goof ball that had no ambition to check,,,,. I also called pertronix for an electronic ignition and they have it for 74 and 75 and they said it wont work on a 79. I dont beleive there is a difference. :cry:
PostPosted: Thu Aug 28, 2003 4:08 pm
there is company in CA that will custom grind you a cam of any lift if you look at the subject called I found perforemance parts. That is where I have listed the # to call them at[/b]
 Post subject: CAM
PostPosted: Fri Aug 29, 2003 5:52 pm
Oregon Cam Grinding in Vancouver, WA
$75 + Core
You can always connect an MSD 6A ignition to the stock distributer.
-DK
