It is currently Mon Jun 08, 2026 6:30 am
PostPosted: Fri Oct 23, 2009 4:26 pm
...where is the best place to hook a chain to in order to get a stable and level lift?
1978 engine.
Thanks in advance.
PostPosted: Fri Oct 23, 2009 6:52 pm
i have just gone around the intake (between the middle runners) and the exhaust ... or you will have to make some hooks to attach to where the intake and exhaust would be if you took them off first
PostPosted: Fri Oct 23, 2009 8:14 pm
Thanks for the info. - I was concerned that the aluminum head wasn't strong enough.
PostPosted: Fri Oct 23, 2009 9:22 pm
it seamed to hold up fine and i pulled it with the trany on
PostPosted: Sat Oct 24, 2009 3:14 pm
Most shop manuals will tell you to do it that way. For example, the 3.8 V-6 (aluminum heads) in my Sable comes out like that (per the factory service manual) with the tranny, and that weighs a heck of a lot more than the LUV.
CTMANDU: That clean, shiny aluminum and painted block is pretty. :esurprised :esurprised :esurprised
PostPosted: Sun Nov 01, 2009 3:55 pm
glad i found this. i need to pull my '80 here soon. are there any other general tips or tricks or is this very straight forward ?
PostPosted: Sun Nov 01, 2009 6:25 pm
We pulled ours today with no problems. I hooked one side of the chain to the stud on the intake side of
the head, closest to the water pump.
And the other end to the last stud of the exhaust manifold, closest to the transmission.
PostPosted: Sun Nov 01, 2009 7:22 pm
other than disconnecting the obvious things going to the engine bay from the engine itself is there anything else you need to take off (i know the hood too)
PostPosted: Mon Nov 02, 2009 4:56 am
If you are planning to leave the transmission in, you will need to support it because the crossmember that
supports the weight is at the tail end. Remove the radiator to prevent damaging it. Also the radiator fan.
If yours is an automatic transmission, unbolt the brackets that secure the transmission fluid cooling lines
that run underneath the motor to the radiator.
Basically, unbolt or loosen everything that connects to the engine.
I was able to remove mine the easy way with the intake, carb, fan, exhaust manifold, A/C compressor and
fan belts still attached because I took the truck cab off first... Image
