It is currently Tue May 26, 2026 1:00 am
PostPosted: Sat Mar 21, 2009 9:57 am
hi i have a 1979 chevy luv and i look all over for the rubber seal around the door can any one help me out !!! :D :D thank u ! dragnsd13
PostPosted: Sat Mar 21, 2009 10:28 am
If you do a search, there has been a lot of posts on this topic. I bought mine from Carquest. Wasn't original but real close.
PostPosted: Sat Mar 21, 2009 8:14 pm
same here. I ended up getting some stuff like the original and also some of the adhesive type so i could put some extra in spots that i thought it needed. if you plan on driving it more than five miles a day in the rain, snow or plan on washing it you must have the weatherstripping. I thought I could get by without it but the first time it rained my door panels got soaked in water and my gauges all got wet. just check out the part stores and take what you can get.
:microwave: :chain:
Juice
PostPosted: Tue Mar 24, 2009 5:39 pm
Try Soffseal.com, part number 9004. About $80 for the pair.
PostPosted: Tue Mar 24, 2009 6:51 pm
thanks for all ur guys help
PostPosted: Sat Sep 19, 2009 2:29 pm
I got the Soffseal the other day. How did you make corner fit. I tried to wrap around the corner but that didn't look like it wood last. The next step would be to cut at 45's and glue the ends together. It would have to be some strong glue. I'll wait to see what others have done before I cut up any more of the door seal.
PostPosted: Sat Sep 19, 2009 7:03 pm
that is why i use the dodge d-50 truck seals... they have the corners and fit great... and the wrecking yards only charge about $5 for them
PostPosted: Sat Sep 19, 2009 11:08 pm
I was able to cut the 45, and glue it with that yellow, stringy 3M glue for interiors. I did two trucks and I think one didn't hold, because I did a crappy job on the cut.
Ctmandu's D50 idea sounds great. Even you just used the corner and did a straight cut to glue into your new seal for the rest of the door.
PostPosted: Sun Sep 20, 2009 12:32 am
When I glued in mine from Restoration Specialities, I just streched it right around the corner. I hope this will work out ok for me. So far it has held up, but I haven't had it outside yet because the truck isn't ready yet.
http://www.purerockradio.net/
PostPosted: Sun Sep 20, 2009 4:53 am
Australian LUV Guru
$99AU a pair on Aussie eBay http://cgi.ebay.com.au/ISUZU-CHEV-LUV-T ... 989wt_1057
1980 4x4 KBD40 ISUZU/Chev Luv
PostPosted: Thu Sep 24, 2009 8:45 am
Found these on eBay..
Precision Parts DOOR SEAL chevrolet LUV 75-77 76 1976 ( eBay number #370258759921)
http://cgi.ebay.com/ebaymotors/ws/eBayI ... MEWAX%3AIT
Hope this helps. Less money..
PostPosted: Sat Sep 26, 2009 7:56 am
i also have used the seals from the 82-90 full size chevy trucks you talk about a seal it has the rubber foam it is tite as it can get so far we have d-50 and full size chevy trucks its all up to you guys :wink:
dangerous-toys4life
75 k-5 2x
94 king cab
PostPosted: Sat Sep 26, 2009 10:00 am
You can get new replacement door seals for that era Chevy full size truck at any of those restore/ parts places.
PostPosted: Sat Sep 26, 2009 12:27 pm
i think this must be a problem for the 79 because i have the same issue. with the rain comeing into the cab. This only started when smone tried to break into my truck from the top of the window. Thanks god they didnt know to go from the side of door cause they would have my truck now. Sowhy dont one of you come up with a fool prof way of fixing this cause i need help and i really dont know how to slove it
PostPosted: Thu Oct 22, 2009 7:15 pm
Don't order these. I did, they aren't even close to the originals.
Restoration specialties #990021 were a great fit, but no molded corners, so I just stretched it around the corner. Don't forget the adhesive. I used 22 ft for both doors.
Do not walk behind me, for I may not lead. Do not walk ahead of
me, for I may not follow. Do not walk beside me either. Just pretty
much leave me the hell alone.
PostPosted: Fri Oct 23, 2009 5:45 am
The door seals are a problem with most trucks, not specific to the '79. And yes, Restoration Specialties is the place to go. I think when I ordered I got 25 feet per truck so I would not run short.
PostPosted: Thu Nov 12, 2015 7:58 pm
OK LUV DOOR SEALS.....BEST PRICE I'VE SEEN ...MADE BY SOFTSEAL
Part #: 61-318291-1 .... > Price: $39.99 pr.
http://www.ecklerstrucks.com/chevy-luv- ... 1982.html#
PostPosted: Fri Nov 13, 2015 8:16 am
Good find! Thanks for posting
PostPosted: Fri Nov 13, 2015 8:03 pm
your welcome ...Just sharing the info to help these trucks along.
the only part i wasn't completely sure was the corners are NOT formed and not sure how they sit .
i imagine they could be cut and melted / glued
PostPosted: Wed Dec 30, 2015 7:31 am
I bought mines as a set in ebay doors weather seals, windshield rubber seal. Rear window seal and doors outside and inside chrome trims for $200 shipped from bankgok. Ebay.
My luv project
https://youtu.be/wd5eCjrNL6U
Users browsing this forum: Google [Bot] and 24 guests
