It is currently Mon Jun 08, 2026 7:56 am
 Post subject: Door Locks
PostPosted: Tue Oct 20, 2009 9:23 pm
Where can i get some door locks the ones i have dont work the key just turns and turns and turns....
2006 GMC Sierra 2500 HD
 Post subject: Re: Door Locks
PostPosted: Thu Oct 22, 2009 1:40 am
lol, sounds like you need a donor truck... From what I've seen, these trucks are pretty common in WA, so maybe look through the classifieds, as people usually post there if they find junkyard LUVs
PostPosted: Fri Nov 06, 2009 12:40 am
You can by brand new door lock cylinders from Autozone. I don't know if you have them in Washington. I went to "autozone.com", you can check if there is a store close to you. I typed in 1980 Chevy LUV like mine for the "add a vehicle", so I'm pretty sure it will fit all early LUV's. The price will probably vary in different regions, so be aware. I found two options:
Part No.DL15250,Black,Two locks-with key,$16.99.
Part No.DL15800,Chrome,Two locks-with key,$11.99.
I bought the chrome ones for my truck. They were a little tight when installing. I hit up the doors with a file around the hole where the cylinders go in, and there fine now. Remember the experienced mechanics advice; take apart one door at a time. When putting everything back together, you can look at the other door that is still original, in case you happen to doubt how you took it apart. Good Luck!
1980 Chevrolet Luv Truck 4WD
1995 Honda Accord VTEC Coupe
1959 VW Double Cab Pick-Up
1968 VW Deluxe Microbus w/camper interior
1968 VW Beetle 4dragracing w/fiberglass flip-frontend
PostPosted: Fri Nov 06, 2009 12:42 am
whoops that first "by" was supposed to be "buy".
PostPosted: Fri Nov 06, 2009 12:53 am
I ended up going to AutoZone to get them i didnt put them on though my friend and i decided to part it out/ Junk Yard it
Users browsing this forum: Bing [Bot] and 39 guests
