It is currently Mon May 25, 2026 4:23 am
 Post subject: jet sizes
PostPosted: Tue Oct 13, 2009 8:50 pm
any suggestions on jet sizes for a weber 32/36 on a stock 76 luv? altitude 500-1000 ft.it idles great n runs smooth at speed but craps out on acceleration,sounds like it is bogging down when the tranny kicks down,"auto tranny".havent had a chance to check the plugs yet.also fuel pump is 3.5 psi,too much?
76 mikado project,mean green
 Post subject: Re: jet sizes
PostPosted: Wed Oct 14, 2009 7:19 am
my fuel pressure is at 4 psi. thats pretty regular with carbs. i couldnt find any different size jets for my weber. but i also live and the 500 foot level. i had the same problem you did. what i did was take off my weber and found out that my power valve was bad. so if i were you i would but in a new gasket kit. along with the power valve and float seat. if that still doesnt help then it might be something with your ignition.
Users browsing this forum: Bing [Bot] and 17 guests
