It is currently Tue Mar 17, 2026 2:28 am
Post new topic Reply to topic  [ 1122 posts ]  Go to page Previous  1 ... 13, 14, 15, 16, 17, 18, 19 ... 57  Next
 Post subject: Re: LUV II
PostPosted: Wed Oct 07, 2009 6:35 pm
pre heat then drill a hole at the end of the crack if its was broke just stick weld it with a nickle based rod
PostPosted: Wed Oct 07, 2009 8:07 pm
I have also used stainless steel welding rods (they're less expensive) for welding cast iron but Nickel is definitely stronger.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Thu Oct 08, 2009 12:09 pm
well back on subjuct the truck is awsome its coming along nice wish i didnt have to get rid of mine .
PostPosted: Sat Oct 10, 2009 8:28 pm
LSX LUV Owner
drop spindles on.. crossmember narrowed 3".. started welding crossmember in..
PostPosted: Sun Oct 11, 2009 11:28 am
LSX LUV Owner
PostPosted: Sun Oct 11, 2009 4:30 pm
LSX LUV Owner
PostPosted: Sun Oct 11, 2009 10:19 pm
8O 8)
PostPosted: Mon Oct 12, 2009 11:08 am
one day man i hope i can lay my truck out next to yours :D
PostPosted: Mon Oct 12, 2009 5:40 pm
LSX LUV Owner
that would be sweet!
PostPosted: Mon Oct 12, 2009 8:53 pm
u think u ll take urs to any shows this upcoming season?
PostPosted: Mon Oct 12, 2009 9:03 pm
LSX LUV Owner
nah i doubt it will even be close to driveable.
once i get the front bag setup done, rear link setup/bags, body/bed mounts.. truck will go back to shed for a while. then dads anglia will come to garage and i will redo his rear frame rails.
PostPosted: Mon Oct 12, 2009 9:24 pm
booooo lol wish i lived closer to ya hahaha
PostPosted: Tue Oct 13, 2009 9:36 pm
LSX LUV Owner
got cab on today.. frame clears the bottom of cab by like 1/2" easy.. will have room to run fuel lines on top of rails. woot. shitty blurry pics will do for now..
thought id add a little flare to the truck..
man i love me some 22" tall tires.. no firewall tubbing FTW!
PostPosted: Tue Oct 13, 2009 9:45 pm
Man what a scary pic...
PostPosted: Tue Oct 13, 2009 10:57 pm
:esurprised = last pic
PostPosted: Wed Oct 14, 2009 4:03 pm
hey what control arms do you have on the front
Epic Fabrication.
KAOS
PostPosted: Wed Oct 14, 2009 5:44 pm
Today at work we printed a little magazine called STREET SEEN that has a lot of pics of bagged cars and trucks. It is a regional mag for the Houston area.
Now I know what "bagging" is... Image
PostPosted: Fri Oct 16, 2009 8:20 pm
LSX LUV Owner
got body squared up on frame, tubes cut, and tacked up onto frame.. they will have two more tubes per mount to make sure its good and rigid. i spaced cab up off frame 1/4". will have to trim pinch, or fold it over some so the entire weight of truck isnt sitting on it..
PostPosted: Sun Oct 18, 2009 7:45 pm
LSX LUV Owner
body mounts all welded up.. no pics as truck is on ground now.. tranny tunnel hacked out, motor sat in.. not positioned right yet. just stock in there to get a rough idea...
PostPosted: Mon Oct 19, 2009 6:40 pm
LSX LUV Owner
got the front clip all bolted up. a little more trimmed out of the tranny tunnel, motor pushed back some more. still might need to go back another 1/4" for oil pan/crossmember clearence. need an oil pan :(
