It is currently Tue Jun 09, 2026 1:25 pm
PostPosted: Fri Oct 09, 2009 1:39 am
I've been doing some reading on here and found that i can use a 5 speed from a newer model Isuzu. However, I find myself in the awkward position of not being able to find something locally. My question is this, what other 5 speed transmission can I install without too much fuss? I was already thinking of dropping a 2.3 4cyl and T5 combo from my brother's donor S10, but i dont want to have to do the entire engine if I do not have to.
Any thoughts?
PostPosted: Fri Oct 09, 2009 9:30 am
What are you driving?
PostPosted: Fri Oct 09, 2009 10:37 am
oops sorry, forgot to mention that.
i have an 80 luv, 2wd 4 spd
PostPosted: Sat Oct 10, 2009 1:40 pm
so, anyone have any ideas?
PostPosted: Sat Oct 10, 2009 10:52 pm
Have you tried car-part.com? They may have something within reasonable driving distance. Any '88-'94 2wd w/ 2.3 engine should work. You may also need the drive shaft, I think the splined portion that goes into the tranny may be different than a LUV, and the differential yoke on a LUV is smaller than on a later pickup. The 5spd is the same length as the 4spd, but if the tailshaft splines are different your LUV drive shaft won't work- will have to combine the two shafts.
PostPosted: Mon Nov 02, 2009 11:36 pm
ive looked, but so far nothing.
anyone know if a T-5 5spd will work if i change out the bell housing?
PostPosted: Tue Nov 10, 2009 11:53 pm
i got 2 willing to sell one 200.00
Users browsing this forum: Bing [Bot] and 16 guests
