It is currently Mon May 25, 2026 10:55 am
PostPosted: Sat Oct 03, 2009 12:32 am
:lol: I couldn't resist,spinal tap ya know,anywho are h.d. valve springs available for the g 180 -200? also for those who have had their cams reground, any valve to piston clearance problems?
76 mikado project,mean green
PostPosted: Sat Oct 03, 2009 2:12 am
Shouldnt be a problem.
Any cam joint worth dealing with should be telling you if your cam is coming back with enough extra lift to cause internal clearnace issues.
What pistons are you useing in the build??? Std type dished top?? Flat tops??
Bob.
PostPosted: Sun Oct 04, 2009 6:27 pm
not sure yet,still in the planning stages.due to financial constraints I might have to do the top end first and leave the bottom end stock till a later date.at that point will try to find a g 200 long block.
PostPosted: Sun Oct 04, 2009 9:17 pm
std pistons in a G180 are a dish top as far as i know. Shouldnt have any clearance issues.
Shouldnt need anything more than a std bottom end.
Bob.
PostPosted: Sun Oct 04, 2009 11:27 pm
yeah,not much you can do,maybe have the rods shot peened but that might be overkill.
PostPosted: Mon Oct 05, 2009 12:37 am
Nah not much you need to do.
The crank and rods will handle a fair bit, will handle heaps more than cast pistons can deal with.
What you should do if you want to build up a hot G180 or G161 is do a bit of research on a guy that calls himself 'gemracing' Darren Hunter is his name. He has had a stock block G161Z turbo down the 1/4 in under 10 seconds.
Cheers, Bob.
PostPosted: Tue Oct 06, 2009 12:32 am
ive seen his site! bit out of my price range.ive got a twin sidedraft inlet manifold and I am currently looking for carbs for it.will go with reground cam and a few odds n ends before the cash runs out!
PostPosted: Tue Oct 06, 2009 3:28 am
You dont have to buy one.
Just watch listen and learn.
cheers, Bob.
PostPosted: Fri Oct 09, 2009 9:13 pm
ive been over that site believe you me.
Users browsing this forum: Bing [Bot] and 17 guests
