It is currently Wed Feb 18, 2026 10:12 am
Post new topic Reply to topic  [ 73 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: EJ20 LUV
PostPosted: Thu Jul 16, 2009 3:43 am
So I have started my build. 1974 2wd Chevy LUV with a 2003 Subaru WRX 2.0 Turbo motor.
The plan
Engine:
Bored .020 over
Forged rods and pistons
Running on E85
Truck:
Outside AS IS
Under the hood super clean.
 Post subject: Re: EJ20 LUV
PostPosted: Thu Jul 16, 2009 9:29 am
sound good... those are jeep rims right? always wondered what they would look like on the luv...
PostPosted: Thu Jul 16, 2009 11:16 am
84 wagoneer. I was looking for the turbine and this is the closest I could find. I like them.
PostPosted: Thu Jul 30, 2009 12:31 pm
Got some parts today from http://gpiperformance.com/. Will be taking the .02 over pistons to Bearing Services today to have the cylinders bored to the pistons size. This is cheaper than getting custom pistons made.
PostPosted: Thu Jul 30, 2009 9:00 pm
thats smart
75-luv mikado-V8 350 soon
PostPosted: Thu Aug 13, 2009 12:48 pm
Well got the short block back today and now I have NOOO money till nexted paycheck :(
Also pick up 02WRX ECU and wiring harness
PostPosted: Thu Aug 13, 2009 12:49 pm
That looks...weird... 8O
PostPosted: Thu Aug 13, 2009 12:53 pm
I know. The first time that I saw the front engine horizontally opposed engine I was like WTF.
PostPosted: Fri Aug 21, 2009 3:42 am
Sence I'm a little light with the money right now. It is time to do all the stuff that doesn't take any.
I took the motor and trans out and next is to start on the rats nest of the ECU
PostPosted: Sun Aug 23, 2009 6:04 pm
:esurprised MAN! i wish I would of thought of doing that. I luv Subaru been a fan for several years but have been disapointed in there new body change. but with what your are doing thats the best thing that has happen to subaru. put the motor in the luv. keep us posted on the progress. :D
1975 luv daily driver.
Project-soon to be revived
PostPosted: Tue Sep 01, 2009 12:45 pm
With time and no money I have started the wiring
I have traced all wires coming out of the ecu and now for the other 2/3 I need to find out what they are and cut them out.
Next week I can get my long block done. I got some overtime that should pay for the seals and gaskets.
Well back to the rats nest.
PostPosted: Tue Sep 01, 2009 7:45 pm
is it a short block or a long block??? and a 2cyl?
PostPosted: Wed Sep 02, 2009 12:19 am
The pic is of the short block from the side. Subaru engines are setup like the old VW aircooled rear engines. Subarus are in the front and are watercooled. but the layout is the same idea also know as a boxer engine.
the engines are also used is small aircraft.
PostPosted: Wed Sep 02, 2009 6:56 pm
So the question is, will it be AWD or you keeping it 2wd? I know the wheel base is wider, but just woundering :D .
PostPosted: Wed Sep 02, 2009 8:14 pm
I wish I could keep the AWD. I will be looking into it next year but for now it will be RWD.
I am using the WRX trany but I will be converting it to RWD only and plugging the the front axle holes.
PostPosted: Wed Sep 02, 2009 8:30 pm
its a four cylinder ?uestluv your just seeing one sind of it
PostPosted: Thu Sep 03, 2009 12:10 am
luvmachine78 I know its a 4 cylinder. never said I didnt know. but thanks for looking out.
PostPosted: Thu Sep 03, 2009 4:48 pm
have any new pic or updates on it??
Epic Fabrication.
KAOS
PostPosted: Fri Sep 04, 2009 3:34 am
No not much. I have been working overtime at work and haven't had much time on the projects. I have do more of the wiring but it just looks like a bigger mess than what I started with. :?
PostPosted: Thu Sep 17, 2009 4:34 pm
well good luck to ya cant wait to see the build up of it
Epic Fabrication.
KAOS
