It is currently Wed May 06, 2026 9:15 pm
Post new topic Reply to topic  [ 65 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Tue Aug 18, 2009 10:47 am
what about with engine set back . . good starting point on spring lbs rate ??? what do you reccommend . . any one ??? Thanks
PostPosted: Tue Aug 18, 2009 6:57 pm
200lb...
PostPosted: Thu Aug 20, 2009 11:04 am
so for now im looking at these . . .non adjustable they show to be 250 for a pair with your choice of springs . . .i need to call and see the width of the bottom mounting and make sure it will fit in the stock lower . . but if worse comes to worse i could widen it by changing one side of the mounting tab . . .what do you think for you guys that have coil overs ??? Im thinking a new pair is better than a used pair ???
http://www.speedwaymotors.com/Bilstein- ... ,7706.html
also mytmouz where are more pics of your truck ??
PostPosted: Thu Aug 20, 2009 6:52 pm
Mine were a little tight on the factory lower mount, but they fit with a little massaging...
viewtopic.php?f=4&t=11796
PostPosted: Thu Aug 20, 2009 10:36 pm
Gotta read better, friend. The kit comes with one (1) coilover, spring and hardware for the price
PostPosted: Fri Aug 21, 2009 5:17 am
Still like the QA1's. They fit good either way you mount them on the top. The bottom fits right in.
PostPosted: Fri Aug 21, 2009 8:09 am
where is the best place to buy them . . . im gonna order monday
PostPosted: Fri Aug 21, 2009 9:11 am
PostPosted: Fri Aug 21, 2009 9:46 am
I got my QA1's from summit and used the stud mount conversion on mine.
Just had to modify the original shock tower
PostPosted: Tue Aug 25, 2009 1:38 am
So for a stock engine, what weight springs should i get, like 180 or less. And where can i get mounts for the top of the shocks, or should i just make them??
"If it wont fit, force it, if it breaks, then it needed to be replaced anyway..."
PostPosted: Tue Aug 25, 2009 5:38 am
I did get 250's for my V8
Most have to fab the shock mount on the top. Ihad some pics of mine on here somewhere in the forum.
PostPosted: Tue Aug 25, 2009 1:29 pm
So an engine that weighs half of yours should do fine with 160 to 180 pound springs. And what did you do as far as removing the torsion bars, thats the part i still dong really get. You just take them out and thats it or is there more??
PostPosted: Tue Aug 25, 2009 5:11 pm
Just take them out . I put the shaft back in that the front bolt threads into. So you are using the original 4 cylinder? i would think the lesser springs would be ok but not sure.
I would go with a more knowledgeable persons answer than mine. I know my front sets down low but I can raise the QA1 springs up with the adjustment on them.
PostPosted: Sun Oct 25, 2009 11:36 pm
any coilover would do right? as long as they are the right length im assuming, whats the length that everyone uses? i have a 79 luv and wanna do this but im completely confused on what i need to start with.
PostPosted: Mon Oct 26, 2009 6:11 am
should . Just be sure you have the right shock length compressed and expanded. I got my QA1's from summit but you can find good used ones from roundy round guys and make your own mounts.
PostPosted: Mon Oct 26, 2009 8:39 pm
what about the bottom? and what length is everyone else using?
PostPosted: Thu Dec 17, 2009 2:18 am
what would happen if you just took the torsion bars out for a v8 and then took some adjustable gas shocks for the front? would that work? or could you just leave the torsion bars off? what about taking and slipping a long spring cut to length over the existing shocks?
PostPosted: Thu Dec 17, 2009 6:26 am
Might work as long as you had the ride you wanted and would support the weight and not get a lot of bounce or shimmying.
PostPosted: Thu Dec 17, 2009 12:55 pm
Once you remove the torsion bars the front end will be setting on the bump stops. Zero suspension travel.....
PostPosted: Sun Jan 17, 2010 12:28 pm
haha yea i got that, so i think what im going to do is just find a long stiff coilover and cut the spring to a few inches longer than i need and put it over the existing shocks there that way i can take the torsion bars off.
