It is currently Mon Jun 08, 2026 5:11 am
PostPosted: Sat Aug 22, 2009 12:32 pm
On my 4X4 I saw an oil leak. Traced it to the dipstick. Seams the lower end of the eng. is presurizing and pushing it out the top. Any ideas on what to look for for a fix?
I checked the hose from the oil pan up the the check valve, I blew into it (down to the oil pan) and it gurgled a bit then was clear.
The dipstick stays in place, oil just seeps around it, and down the the lowest point, and then onto the ground.
This truck had not dripped a drop yet until now. :econfused
PostPosted: Sat Aug 22, 2009 2:11 pm
Is the oil comming from the top of the dipstick tube or where it fits into the engine block? Is could be loose where it is mounted.
Rick
Loranger, La
1980 Stepside LUV (Again)
PostPosted: Sat Aug 22, 2009 5:13 pm
i had that happen kinda on a chevy 1 ton 6.5 diesel. except oil was coming out of more than just the dipstick tube.. anyway long story short turns out was a bad cylinder and am in the process of replacing the engine
zyanug
76 fleetside 350hp 1968 327cu
___/__l____
[_@l__l__@_]***
TILTED wrote:
Boobies!!!!! 8O
PostPosted: Sat Aug 22, 2009 5:26 pm
This is coming from the top of the tube, where the dipstick goes in. The dipstick will have oil up the the rubber seal til I wipe it off and re dip it. Then it will be normal.
PostPosted: Sat Aug 22, 2009 6:29 pm
I would say a plugged PCV system. Should normally draw the crankcase oil vapors through the small hose from the valve cover to base of the carb for reburning. I remenber it being between the carb and the valve cover, a short hose.
PostPosted: Thu Oct 08, 2009 7:39 am
my truck is a 79 and i had the same problem trued out i was not running the right oil in the truck our truck need 20w50 thats whats they are made to run off . but it could too mean that you have a bad o ring on a piston. let me know what weight oil you are running if it not 20w50 change it you will see
PostPosted: Thu Oct 08, 2009 10:45 am
I have 20W50 in it.
I cleaned out the check valve on the fire wall, but that didn't fix it. I just unplugged the hose from the oil pan that goes to that valve, and have no problems since.
PostPosted: Mon Oct 12, 2009 11:02 am
good deal i didnt think about that
Users browsing this forum: Google [Bot] and 57 guests
