It is currently Mon Jun 08, 2026 3:56 am
PostPosted: Tue Aug 04, 2009 6:01 pm
Hi does anyone know where I can find a speedometer cable for my truck, it has the square end with the clip on the speedometer end and the other end is also squared like the other end. I bought one off Ebay but it has a big round end with a knotch that goes in the transmission and it wont work, it has to be a small squared end that goes into the transmission, any help would be very thankful, thanks Terry
1981 Chevrolet Luv/Pup, Long Bed, 3-Speed Automatic Transmission, 2 Wheel Drive, Gasoline Powered
PostPosted: Thu Aug 06, 2009 7:36 am
Do you need the cable sheath as well as the cable itself? Normally, you just replace the cable. If no luck here, you might want to check at IsuzuPup.com.
PostPosted: Fri Aug 21, 2009 9:32 pm
I checked the speedo cable that is used in the 81-82 Luvs and the 82-87 Isuzus, and I have one that is still in the factory package. The package is unopened, the part numbers are GM # 94253993, the Isuzu # 8-94253993-2. These are stamped on the plastic "envelope", another possibly generic part number stamped on the outside above the parts tag is 5569 000.
I'll sell the one I have for $45. plus $10 shipping, I just paid that much for a special cable to fit my 78 Luv, T 350 to a 5/8" aftermarket speedometer, so I think that's fair.
Since it is still sealed I don't wish to open it, but if you want a picture of it since you can easily see both ends let me know,
pinkertondusty@aol.com
Users browsing this forum: Bing [Bot] and 41 guests
