It is currently Mon Jun 08, 2026 1:41 am
 Post subject: Mount
PostPosted: Thu Jul 23, 2009 8:56 pm
was just curious. On the front under the radiator support there is a rubber grommet under each side. Does the tall one go under the support and the 2 small ones go under the frame or vice versa. i can't remember since it has been so long. I have the 2 tall ones on top but not sure if that is right or not.
 Post subject: Re: Mount
PostPosted: Fri Jul 24, 2009 5:21 am
If I am looking the right place, the thicker one goes on the bottom.
PostPosted: Fri Jul 24, 2009 11:55 am
were the bolt goes through the radiator support and frame there is a rubber mount between the support and frame then another rubber grommet on the bottom between the frame and nut.
Users browsing this forum: Bing [Bot] and 56 guests
