It is currently Tue May 26, 2026 5:57 am
PostPosted: Thu Jul 09, 2009 8:45 am
yup thats blue
what tire size can i run up front i was thinkg a 16X7 rim0 offset
recently purchased 72 luv truck
1970 dodge charger- 500ci 5 speed
ram big horn 5.7 hemi
PostPosted: Sat Jul 11, 2009 11:50 am
I have 16" on mine front and back with low profile tires up front. I will check on the tire size tomorrow afternoon and let you know.
Rick
Loranger, La
1980 Stepside LUV (Again)
PostPosted: Mon Jul 13, 2009 3:32 pm
hey chevy luv 80 thats a real nice truck you got there!
and maparich, i luv that color! llooks like your really making
some good progress! good luck with the build!
~Dustin
PostPosted: Mon Jul 13, 2009 7:37 pm
Helps to know if you are dropping it or leaving it stock height.
PostPosted: Tue Jul 14, 2009 7:00 pm
thats a good looking truck luv80
planning on a 1" drop running 16" rims. really lookinf for the front rim tire combo. i will try and fit the biggest tire in the back i can.
PostPosted: Tue Jul 14, 2009 7:02 pm
the more i look at chevyluv1980 truck the more i like it.
i like that stance can you tell me your rim size also
PostPosted: Tue Jul 14, 2009 7:26 pm
:signhijacked what motor is that?
75-luv mikado-V8 350 soon
PostPosted: Tue Jul 14, 2009 10:51 pm
I will guess a Nissan
PostPosted: Wed Jul 15, 2009 5:24 am
:signiagree :roll:
PostPosted: Wed Jul 15, 2009 6:39 am
its ca20 the fuel inj and ecu are comin out of a 86 200sx
PostPosted: Thu Jul 16, 2009 6:46 pm
Wheel size is 16x7. Need the offset, if any, also?
Rick
Loranger, La
PostPosted: Thu Jul 16, 2009 9:03 pm
yes please offset and tire size
PostPosted: Sun Jul 19, 2009 9:04 am
As soon as I repair my air compressor I'll get those dimensions for you. No strength left in my hands and arms to break the lug nuts loose manually.
Rick
Loranger, La
PostPosted: Wed Jul 22, 2009 8:48 pm
I measured the offset to the bead seat and got 4-5/8". It's 5" to the edge of the rim itself. Alll four rims are the same. Tires up front are P205, 55, R16 and the rear is P235, 65, R16. As soon as I get a 5 speed tranny to fit my truck I plan to put my 14" rims and tires on it. The 14" tires only have 15 miles on them but the rims need serious cleaning and painting. Eventually the rims in the pic will be available, but not sure when as I am having problems finding a tranny.
If you need any more info, let me know..
Rick
Loranger, La
PostPosted: Thu Jul 23, 2009 9:19 am
I appreciate the info how much space do you have with that rim tire combo to the frame rail when the tire is cranked all the way. I know I owe you a favor and do quite a bit of traveling for work, and if I’m in your neck of the woods ill drop off a 6pack.
Here’s some updated pics of my luv
PostPosted: Thu Jul 23, 2009 9:20 am
hey i spent some time in leesville LO. is that close to ya
PostPosted: Thu Jul 23, 2009 5:30 pm
Nope. I'm about 20 minutes from the Mississippi/Louisiana state line. Leesvile is closer to the Texas state line.
Rick
Loranger, La
