It is currently Sun Apr 05, 2026 6:08 pm
Post new topic Reply to topic  [ 42 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: 75 pro street
PostPosted: Wed Jul 08, 2009 4:25 pm
Why did you pull the cab to install the engine??? Looks like you are doing alot of unneccesary work. Do you have a plan for the truck. I did mine and had it mapped out so I would not be duplacating work. Why do things twice. That is also why I asked you what type of rear end you had planed. Do you know what size tires you want to run????
PostPosted: Thu Jul 09, 2009 12:32 am
hehehe i havnt planed a thing all i know is im putting a 350 with a th 350 trans and a 9inch and i have no idea what size tires and maybe 355 gears?
75-luv mikado-V8 350 soon
PostPosted: Thu Jul 09, 2009 8:49 am
:signiagree
I'm with him on planning. E.g., one of my ultimate goals is to put A/C in my LUV. But to do that, I have to do the following things, in roughly this order:
-Eliminate stock air cleaner, replace with open element,
-Rebuild carburetor so the truck will run well enough to have AC,
-Eliminate smog pump and smog equipment to mount the AC compressor where the smog pump was (notice I had to take care of the air cleaner before this),
-Find A/C compressor and fab a bracket (no point in doing that until I do the above)
-Dynamat the interior,
-Replace interior/door weatherstripping,
-Replace cracked windshield and old grommet,
-Block off/make manual louvers for the fish gills in the back of the cab,
-Fortify cooling system by having radiator recored to three row and adding 5 blade flex fan,
-don't forget to add a bigger alternator (GM 10si 63 amp)
Then, and only after all that crap, would I even consider ordering a condenser, dryer, evaporator, and whatever actual AC parts I need. It won't pay to buy all that stuff and install it now because the truck won't run, it'll overheat, and I'll waste any cold air I do get because of bad weather stripping.
YMMV, and I decided to put in $0.03 because hopefully that is not yet worthless because of inflation. :lol:
PostPosted: Thu Jul 09, 2009 12:57 pm
Start planning. How would you know what gears to run without knowing tire size, stall converter, cam etc.
PostPosted: Thu Jul 09, 2009 1:08 pm
unless you are planing on tubbing bed and narowing the frame to fit a big tire 373s are the way to go they are good for cruzing around and if you do want to get up and go they will do that to. but if you do go with a big tire 411s or 436s or 456s depending on what you are doing with the truck
PostPosted: Sun Jul 12, 2009 1:06 am
im bowseing summit and started added things i need for this project came out to $1,592.25 8O which i guess aint to bad but more than i have now so i guess ill but it piece by piece 8)
B&M 80681 - B&M Z-Gate Shifters -$119
Edelbrock 9905 - $224
Flowmaster Super 40 Series Delta Flow Mufflers-$95
Holley Street Dominator Intake Manifolds-$171
Hooker Super Competition Engine Swap Mount Kits-$131
hooker trans mount -$124
Summit® Camshafts-$52
Summit® Blueprinted HEI Distributors-$89
Summit® Water Pump Pulleys2-Groove, Aluminum-$42
Summit® Crankshaft Pulleys-$24
Summit® Block Hugger Headers 1-5/8 -$99
Weiand Action Plus Mechanical Water Pumps-$96
Griffin Aluminum Pro Series 19x22-$179
Flex-a-lite Syclone S-Blade Electric Fans-$122
hearing that 350 fire off priceless :lol:
now im begining to plan i hope lol i dont know much about gearing tho
PostPosted: Sun Jul 12, 2009 1:35 am
im calling this project Fast Luvin. lol i hope know one else had came up with this b4 and i didnt try to hard on it.
PostPosted: Thu Jul 16, 2009 7:39 pm
sent old rob the money for the mounts today hope fully get them in by next week than the build can commence again
PostPosted: Thu Jul 16, 2009 7:43 pm
Plan on doubling this amount at least .
PostPosted: Thu Jul 16, 2009 8:12 pm
for the over all project yes but my plan right now is getting that motor to work and every thing like that than trans than rear end
PostPosted: Thu Jul 16, 2009 8:45 pm
You may have forgot a few things
Gasket set
hoses
belts
fluids
driveshaft
misc fittings
I can go on forever then miss a few things that Hotrod 80 would have to fill in. He is correct on the X2 for the price. Trust us, we have been there, done that and had to explain it to our wives.
PostPosted: Thu Jul 16, 2009 10:26 pm
i knows thats not everything but thats the stuff at summit i want i can gtet the hose etc at my auto parts store i go to here in azusa and even get the fluids for free lol
PostPosted: Sat Jul 18, 2009 1:59 pm
bought the intake and aluminum puleys for the shorty water pump
PostPosted: Sat Jul 18, 2009 9:34 pm
LSX LUV Owner
1600? thats it? like others said.. itll still be more than that with all the nickle and dime things..
i did some very rough figuring for the big things i need to be driveable.. and it came to 6k.. and then i still need to buy a rebuild kit for my 5.3, maybe tranny rebuild, stall.. then i will have to buy another set of tires n wheels.. the ones i want are around 2k for just wheels.. then paint and body work..
PostPosted: Sat Jul 18, 2009 10:24 pm
i havnt added the trany rebuild or getting my rear end cut in to that driveshaft etc its just to get the motor to turn with out a rebuild on it
PostPosted: Mon Jul 20, 2009 8:22 pm
waiting for old rob to get back to me on the motor mounts sent him the $$ no reply on here or email :(
PostPosted: Tue Jul 21, 2009 2:01 pm
In case you did not get them, here are copys of the Emails recieved and sent. Name and e-mail address were intentionally x out for privacy.
Subject: Re: luv mounts
Date: Mon, July 20, 2009 19:07
To: "XXXXXX XXXXXX" <XXXXXXXX@hotmail.com>
Priority: Normal
Options: View Full Header | View Printable Version | Download this as a file | View Message details
XXXXXX; the delivery confirmation number is 0309 1140 0000 7165 6979Thank you
Subject: luv mounts
Date: Thu, July 16, 2009 18:23
To: "old rob" <sales@powerbyace.com>
Priority: Normal
the money order just mailed today so u should get it by Monday $XXX.XX. for the record my real name is XXXXXX X XXXXXX. so u know its my money order and thanksagain for helping me get one step closer to getting that v8 in my luv
___________________________________________________________Hotmail® has ever-growing storage! Don’t worry about storage limits.
PostPosted: Tue Jul 21, 2009 7:06 pm
thanks i got the mounts today thanks and they came at the same time as my holly intake and my pulleys thanks again rob
PostPosted: Tue Jul 21, 2009 8:57 pm
ok put the mounts on by hand to get a looky at them. now i cant wait to get the rest of the stuff off the list thanks rob. screw the summit junk. ill get it from my parts store faster. hopefully ill get the motor running soon. the left one is the driver side right and the box goes toward the front of the truck?
PostPosted: Thu Sep 17, 2009 6:45 pm
got my mounts today hope they fit =D
