Perhaps a late reply, but I guess late is better than never.
I have been doing some major parts-pulling from this thing. The entire drivetrain seems excellent, it starts right up, drives, etc.
I have yanked off one of the fenders already, and noticed that it is aftermarket. The reason it was yanked is that rust ate through the entire front of it. Then, moving towards the back of the truck, I went to replace the bushings on the door, but the bolts on the hinges are so rusted out that they just free-spin in the body...Since I think this is the only part of the truck that has a VIN number, I don't even think I can replace just the door without a ton of extra work (legal wise). The bed (where the wheel wells are welded to the sides) are starting to rust to the point where I took a sawzall to remove the rust, and then grinded, sandblasted, and primed the resultant holes until it gets a little warmer out for the paint to cure.
It looks like I had a shade tree mechanic working on it before, because there was RTV where BOND-O should have been used as body filler (lol).
Yesterday, a friend and I removed the bed, taillights, wiring, and fuel filler neck. I examined the frame for more damage. The passenger side has at least 3 Feet (1 Meter for INTL reasons) of a rust hole in it -- It looks like somebody already welded plate over this hole, and the rust pretty much just started at their weld.
The drivers side has about 6 Feet of the same problem (2 Meters)...
I'm starting to think I'm in well over my head with this. I really wonder if an S-10 frame would work, or if there is some way to stop the rust and fill this in...Mind you I'm on a rather limited budget like everybody else these days. At least if I get the frame fixed, then I'll have good reason to put in some floor boards
