It is currently Mon Jun 08, 2026 6:47 am
 Post subject: ARGH!!!
PostPosted: Sun Jul 05, 2009 8:42 pm
:smt013 i tried to a smart guy and take off my ac belt speaking ther is no freeon in the lines . i losed up one of the bolts on the compressor and i couldnt get the other side to losen so i started looking at it and i noticed the tensenor on the bottom. i started to losen that up and the bolt crack off. so i got madd and cut the belt....
75-luv mikado-V8 350 soon
 Post subject: Re: ARGH!!!
PostPosted: Sun Jul 05, 2009 9:17 pm
No habla espanol??? Image
PostPosted: Sun Jul 05, 2009 9:48 pm
:signiagree
PostPosted: Sun Jul 05, 2009 10:47 pm
Both of my tensioners had adjuster bolt problems too. I removed the whole thing, got a new bolt for it and put it back in.
PostPosted: Sun Jul 05, 2009 11:04 pm
yeah ill do that when i get my ac working cuz i dnt really need it speaking i dnt use my ac
PostPosted: Mon Jul 06, 2009 12:33 pm
You keep talking about installing a V-8 and pro-streeting your truck. If a A/C bolt is able to get the best of you I recomend not even thinking of mod'ing your truck. I bought my LUV with a small block and then moved the engine mounts, replaced the bed and cab, replaced a ton of messed up parts the the previous owner did, tub'd it my self , trust me, alot worse things then a stuck bolt will come up. If you do V-8 or pro street your truck get help, either from a friend or Prozak.
PostPosted: Mon Jul 06, 2009 6:51 pm
and the sad part is this is on my daily lol
Users browsing this forum: Majestic-12 [Bot] and 52 guests
