It is currently Mon Jun 08, 2026 4:13 am
 Post subject: Carb issue???
PostPosted: Tue Jun 30, 2009 9:21 pm
I have a problem i belive with my carb every time I put start it up and put it into reverse my truck dies. It is a stock engine and auto tranny with the regular carb. I tried messing with the adjustment screw but it didn't seem to do much. I also don't have the inhibitor switch connected so i can start it in any gear so i started it in reverse and it works just fine i can go through all my gears and it does just fine and i can put it into park also I just cant go from park to reverse with out it crapn out any ideas?
A good friend will bail you out of jail, and even better friend would be sitting in the cell with you saying how awesome that was!!!
 Post subject: Re: Carb issue???
PostPosted: Tue Jun 30, 2009 11:00 pm
Can you go from park to neutral, and then up to reverse?
PostPosted: Thu Jul 02, 2009 12:34 pm
Yea i did it twice the first time it died then the second time it ran very rough.
PostPosted: Fri Jul 03, 2009 6:38 am
On the bottom of the float bole is two plugs that will let you get to the main jets and there is a small chamber there that will collect debris and water.You will have to pull the carb to get easy access to them but i would say that is where your problem is cause the plugs face forward as the jets and when you put in reverse it wold cause the debris to go up and block the jet.Some times this can get full enough that it will cause problems when to take off or when you try to get full throttle and suck the stuff up and then when you back off the throttle it settles back and runs good or better again.This condition can make you think the carb is junk but all it needs is the jet well drained and cleaned.
