It is currently Tue Jun 30, 2026 5:13 pm
PostPosted: Fri Jun 19, 2009 2:30 am
for my senior project, not wealthy enouch so if anyone wants to sell the mounts PM me :)
PostPosted: Fri Jun 19, 2009 11:39 pm
motor and trans mounts for what engine and what trans..
When buying a used car, punch the buttons on the radio. If all the stations are rock and roll, there's a good chance the transmission is shot!!!
PostPosted: Sun Jun 21, 2009 3:27 am
350/th350
PostPosted: Mon Jun 29, 2009 5:27 am
babyblueluv wrote:
350/th350
i had rubber mounts but changed to solid metal mounts,,,i bought mine from summit for cheap,,, moroso brand all metal mounts....if i remember correctly the trans mount was like $20.00 and the motor mounts are about the same price for a set...
PostPosted: Mon Jun 29, 2009 4:08 pm
can you send me the link for that? thanks
PostPosted: Mon Jun 29, 2009 11:26 pm
I think he's looking for the adapters to install the engine.
You'd be looking for either bolt-in www.powerbyace.com , see technical section for info, pics at www.photobucket.com/v8luv For weld in, try Summit look for hooker mounting kits.
You can make your own, however for the time you'll spend you could most likely earn the cost of a kit and no worry's.
PostPosted: Tue Jun 30, 2009 3:23 am
i think advanced adapters sells bolt in mounts and summit sells weld in frame mounts....i just built my own,,,cut out your old mounts and weld in some thick wall square tubing....mine has been holding up for years several engines later...
Users browsing this forum: Google [Bot] and 19 guests
