It is currently Tue May 05, 2026 11:32 pm
 Post subject: Pulley setup
PostPosted: Mon Jun 29, 2009 5:53 am
I wonder what kind of aluminum pulley kit I can find to lower my alternator down on the passenger side of the block. i am wanting an aluminum single crank pulley and mount to match it up. i am using an electric water pump so I need something to line up as a bolt on kit. Anyone other than summit or jegs or somebody fairly reasonable sle a good set up or does anyone have one on the forum for sale.
 Post subject: Re: Pulley setup
PostPosted: Mon Jun 29, 2009 7:35 am
I tried a couple of the low mount alt brackets for a mini alt. on mine. None of them worked. They all would stick out enough to hit the frame. I fabbed a set of mounts by hand to do it. Mine bolts to the 2 holes that in front of the block down low that are for the front cradle mounts like on a 56 or so Chevy. I ended up doing mine on the drivers side due to the routing of the lower radiator hose...
PostPosted: Mon Jun 29, 2009 9:39 am
Forgot about the hose. My raddy only is 16 inches from top to bottom so I might be below the hose but doubt it. Drivers side might be better or just leave it on top and run an aluminum pulley on the crank
PostPosted: Mon Jun 29, 2009 10:48 am
i drive my alternator off the front u joint.
works decently as long as you dont have any real serious power draws.
A.j.
PostPosted: Mon Jun 29, 2009 11:45 pm
We use to put the altenator up on the manifold on the right side, when we put the air compressors in on the left. However that was using a stock belt driven WP.
PostPosted: Wed Jul 01, 2009 12:45 am
In regards to your pulley setup? Log into a company called "Alterstart" this is a company out of Dallas and they make virtually every kind of alternator and a/c compressor mounts you will ever need!
And they have an online catalog you can check out, I recommend them highly, you can buy kits for low mount, high mount, dual low mounts, etc.
I think their main business in in the pickup and truck alternaor bracket business, but they sure have a lot of kits, several people also sell their kits on e-bay.
In regards to choosing the pulleys, I bought a "short"aluminum water pump and was able to choose my pulleys at a local speed shop. Quite reasonable too.
Good luck,
scjconv
PostPosted: Wed Jul 01, 2009 7:49 am
COOL thanks a bunch
PostPosted: Thu Jul 02, 2009 8:48 pm
dr_frankenstein56 - You drive the alternator off the front U-joint? Got to see a pic of it..
Rick
Loranger, La
1980 Stepside LUV (Again)
