It is currently Mon Jun 08, 2026 10:11 am
 Post subject: A/C idle up solenoid
PostPosted: Sat Jun 27, 2009 11:34 am
I have a 1980 Luv Mikado with ice cold air, but the idle up solenoid is not working. I tested the connector where it plugs into the harness and it has power when the a/c switch is on, so this tells me the solenoid itself is bad.
I have checked all the local parts houses, az, advance ect and they don't have a listing for it. I even checked Rock Auto parts that I found here on this website with no luck.
If anyone knows where I might find this idle up solenoid, please sing out!!!
Thanks in advance for any input!
1980 Luv Mikado-Daily Driver
1962 Chevy C-10 Stepside- Work in progress
1990 Chevy Suburban- For towin' and haulin'
 Post subject: Re: A/C idle up solenoid
PostPosted: Sat Jun 27, 2009 12:07 pm
Got a pic of it? I have a lot of loose parts that I have no idea what they are...
PostPosted: Sat Jun 27, 2009 1:46 pm
:oops: My bad! The idle up solenoid is working! The adjusment screw it pushes against to idle up the engine when the a/c is turned on was waaay out of adjustment. Made that correction, now the engine idles like its should with the a/c on! Guess I should have checked that to start with. D'OH!! :lol:
PostPosted: Sat Jun 27, 2009 4:35 pm
I was gonna say...... :D
Glad it works now.
