It is currently Mon May 25, 2026 11:17 pm
 Post subject: Torsion bar removal...
PostPosted: Wed Jun 24, 2009 1:53 pm
So if i was to put coil overs on my Luv everyone has told me that i should take the torsion bars out. Should i put anything in the torsion bars place or just rip them out and put the coil overs in.
"If it wont fit, force it, if it breaks, then it needed to be replaced anyway..."
PostPosted: Thu Jun 25, 2009 9:56 am
The coil spring in the coil overs should do the work that the torsion bar does now if you have the right size/wt coil spring.
PostPosted: Fri Jun 26, 2009 4:20 pm
Check out this post I think it may help with some of the questions:
http://forums.luvtruck.com/viewtopic.php?f=7&t=16951&hilit=coilover
PostPosted: Fri Jun 26, 2009 8:02 pm
so that guy basically took out the whole middle part of the suspension and just left it the upper and lower control arms? is that what your getting at??
PostPosted: Fri Jun 26, 2009 10:15 pm
yes in a way. the coilover does the job of the torsion bars so you dont need those and the adjuster and so forth. you have to mod the shock tower fit the coilover depens on what type you get.
1975 luv daily driver.
Project-soon to be revived
PostPosted: Sat Jun 27, 2009 8:26 pm
ok thanks for the info...
