It is currently Tue Mar 17, 2026 11:58 pm
Post new topic Reply to topic  [ 330 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 17  Next
PostPosted: Mon Jun 01, 2009 7:54 am
DHPmike wrote:
ok heres what I have figured so far...
first heres a pic of the stock arm with some lines on it. Forgive me I did it in the only thing I have which is paint.
I need to know the distance from where the arm bolts up out to the steering at its closest point, and in the back from where the arm mounts up back to whatever is behind it. On MYTMOUZs truck theres a tube back there, Im assuming its a header.
I need to know if theres 11" or 12" in between those two points. Id also like to know what diameter the hole is in the frame. I need to know if theres a rubber bushing in there and if the rubber bushing has an outer sleeve what diameter is the hole if it were taken out.
Now look at this pic. The orange is the frame, the pink is the threaded tube that holds the arms, and the black is the arm. the blue is the bag plate and yellow is the bolts.
If theres 11 or 12 inches in there I can make an arm like that. let me know what you think. BTW Im lining up a local truck to go look at in person.
OK, here is what I came up with, it looks like to me for it to work, they will be similar to the Toyota type you have a couple of posts up. The widest it can be without hitting is 7 inches to the outside of the tubes coming off the bushings. The bushing part itself can be as wide as needed for the bushing as the bolts and bushings are behind everything (at least on mine). The side of the a arm that is to the idler arm and pittman arm, can be a max of .500 closer to the idler/pittman, while still leaving enough clearance not to rub. The bolt dimension you requested is .606. Should be pretty easy to open the hole up to 5/8 and use that size bolt. All this is for the lower a arm.
PostPosted: Mon Jun 01, 2009 9:21 am
In this picture the lower arm looks like it will be offset which I am guessing is to help with the strut rod. But it looks like the bag mount will be offset as well, is this the case?
Also will you be compensating for the possible different mounting point height of the spindles? I think I remember from the other post that someone said the S10 spindle was taller than the LUV spindle, does this have to be compensated for when you mount the balljoint in the control arm?
PostPosted: Mon Jun 01, 2009 3:07 pm
The drawing is just to give you an idea. Ill be testing the spindles side by side to determine where they need to fit. The bag plate wil probably be offset to clear the steering.
Michael White
www.dallashotrodparts.com
PostPosted: Mon Jun 01, 2009 8:58 pm
Michael:
Looks like you are working hard on a game plan. Since you have done this a few times :D it is looking like it will be a good one.
PostPosted: Mon Jun 01, 2009 10:18 pm
Could you do a variant that is specifically designed to lift the front end/make it easy to lift the front end? Or could you even do that with these, just using taller coil springs?
Just curious.
PostPosted: Tue Jun 02, 2009 4:34 am
I didnt know any of these had coil springs. If any did like say a 4x4 version the arms are probably different. But I can build lift into arms no problem. I can also do custom built spindles. Im working on some Ranger drop spindles now.
This will start rolling along faster as soon as I get to look at one in person. The uppers I can do without seeing one but the lowers Id like to do more research on. Ill keep you all posted.
Michael White
PostPosted: Tue Jun 02, 2009 5:57 am
When yo do away with the torsion bars you can use the coil overs and get the length and hight you want or put on a stouter spring.
PostPosted: Tue Jun 02, 2009 8:56 am
In my parts stash, I have a Mustang II spindle and a Wilwood rotor. Dug it out and it looks like a good fit, the spindle is a lot shorter than the stock one, but the tie rod placement is correct. Looks to be a matter of finding a tie rod to fit.
PostPosted: Tue Jun 02, 2009 1:28 pm
I was looking at one of my magazines and it looked like a MII spindle was rear steer. My chassis I bought did not have the spindles with it, is the LUV front or rear steer? My guess would be front but that I would ask to make sure.
PostPosted: Tue Jun 02, 2009 1:52 pm
I took the stuff off a car that the drivers side was demolished. That's why I only have one side. It matched up pretty well with my passenger side stuff...
PostPosted: Tue Jun 02, 2009 5:26 pm
Well the S-10 spindle hub face is about the same as the LUV and the spindle shaft is the same length. Im guessing the wheels would be about the same place.
Michael White
PostPosted: Tue Jun 02, 2009 8:04 pm
Sweet!
PostPosted: Tue Jun 02, 2009 9:16 pm
I was looking at a picture in a magazine of just a suspension set up. I could be wrong. I just thought I would bring it up incase someone was thinking of going this route.
PostPosted: Wed Jun 03, 2009 1:41 am
:oops: Sorry, meant coilovers. And I believe the arms are the same, aren't they? (asking someone who knows more about LUVs than me; I've only seen my 4x4...)
PostPosted: Wed Jun 03, 2009 4:42 am
I got some really good pics from a local guy. I may even go look at it since its within 50 miles. I just need to know the diameter of the hole in the frame where the lower arm bushing is. I mean if the bushing and whatever sleeve is on it were removed what the diameter would be.
Im guessing its about an inch and a half. Im sure its metric though.
anyone have that measurement?
Michael White
PostPosted: Wed Jun 03, 2009 1:16 pm
I'm attempting to get this measurement for you. However, I just had surgery and it's making it tough. If anyone has their a arm off and could measure the hole in the frame where the torsion bar goes, it would be greatly asppreciated...
PostPosted: Wed Jun 03, 2009 4:48 pm
The only thing I could measure since mine are on but the front clip off is it looks as if the torsion bar hole with the splines are 1 inch or whatever metric would be. also the bolt that goes through that holds the arm on is 1/2 or whattever metric would be and has the big flat head on it. C an't get to the hole on the support itself but I bet it isn't much bigger than the bolt considering it is bushed on the inside.
Guess I could possibly pop mine back off. Hope someone has one off.
PostPosted: Wed Jun 03, 2009 6:13 pm
I had a local guy measure his. The measurement with the outer bushing sleeve out is about 1.5"
This means that I will be able to use the 1.5" tube like I use on import arms. It will be about 7" long and have the arms bolt to each end of it.
Ill be starting on the uppers this weekend and I should have pics by Sunday night. Ill post here later tonight how Im going to do the uppers.
peace!
Michael White
PostPosted: Wed Jun 03, 2009 9:17 pm
Ok gentlemen and any ladies that may wander in...
Ive taken a couple pics of what Im going to explain. First the pic of a typical crossbar from a Toyota upper control arm. The bushings below it are S-10 ES bushings.
This is what the crossbar looks like out of the arm. I would like to be able to have customers use the stock crossbars since that would make the arms easy to build. But there are so many different minitrucks that have crossbar upper arms and I dont think any 2 have the same diameter crossbar ends. So that would mean getting several different poly bushings. And the main reason I dont use stock crossbars is that the shafts are almost always metric. Therefore I use the same poly bushing on all my minitruck tube arms.
I make them for Isuzu, Mitsubishi, Toyota, Nissan, Mazda, S-10 and now Luv.
Really the only things that matter are the distances outlined here as A B C and D.
First is A, the distance between the mounting bolts. As I have built all these I have found that almost all minitrucks use 13mm or 14mm bolts. These I can replace easily with 1/2" or 9/16" bolts and have no issues. Most cases I dont include mounting bolts and have the customer use the stock bolts. Plus since the 13mm and 14mm are so close to 1/2" and 9/16" I can use 1" DOM with either a 1/2" hole or a 9/16" hole and Im covered. The thicknesses I order are .250" wall or .188" wall and the bolts go right in.
Next for the ends that hold the bushings I use 7/8" DOM since the poly buhsing has a 7/8" I.D. The 7/8" DOM has a .188" wall and that leaves a 1/2" hole. The poly bushing by the way is the Energy Suspension graphite impregnated polyurethane one they sell for use in stock S-10 upper arms. That makes them readily available since the same bushing fits many other GM vehicles.
Inside the 7/8" DOM I force a 1/2" boolt with the head cut off. I leave some sticking out for a nut. I then weld the tubes onto the small tubes that mount the arm. The only thing I have to do is make sure the holes are the same distance apart as stock. Heres a pic of an S-10 crossbar I made so you can see how I make them.
I like having the bolts stick out the end rather than have a threaded hole. With a threaded hole theres always the possibility of the bolt backing out, especially with the arm going up and down thousands of times a day in norman driving.
On the threads sticking out I use all steel stover locknuts and they never back off. simple solution solves the problem. And since I use the same bushing on all these different arms I can use the same ends to hold them. so the crossbar and mounting points issue is solved.
Next is the length of the arm from pivot point in the center of the crossbar to the center of the balljoint (b). A simple measure of that solves that issue as any balljoint has the shaft in the center and its easy to line that up while making the jig.
The next thing is C and thats whether the balljoint is centered or not. Most imports are because they can make one arm fit either side. This one as you can see in the pic is centered. Even if it were offset I still make both sides off the same jig and flip one over. the balljoint angle is a flat 0 degrees and the tubes are flat out as well which works well on a bagged truck.
The next thing is D which is easy because the bushings I use are usually shorter than the factory ones. so no clearance issues there and since these poly bushings are graphite impregnated they never need grease.
So as you can see I already have the uppers figured out and its just a matter of building the jig. These will be no different than any other minitruck upper crossbar arm I make.
I will post pics as soon as I have one made.
When I get ready to do the lowers I will post the same pics and show how those will be made. I have those figured out as well.
Michael White
PostPosted: Wed Jun 03, 2009 9:45 pm
Nice work up. Looking forward to them!
