It is currently Sun Feb 01, 2026 3:44 pm
 Post subject: transmission woes
PostPosted: Thu Mar 12, 2009 8:16 pm
My F250 trans. went out on me. I guess 111thou isn't too bad as hard as I work it. I was told to only expect 50thou when it's behind a Power Stroke. It's at the shop, I'll post more after they diagnose it. I'm sure it will be a total rebuild.
 Post subject: Re: transmission woes
PostPosted: Thu Mar 12, 2009 9:36 pm
Sorry to hear about the loss of your transmission. :smt089
PostPosted: Sat Mar 14, 2009 2:33 am
It's done. My wife picked it up tonight. I will drive it in the am and see how it is. Rebuilt, heavy duty parts and what they call extreme duty converter. ( probably just so they can charge more) And the pan now has a drain plug so I don't take a fluid bath when servicing it. Normally my garage floor ends up looking like I slaughtered a pig.
PostPosted: Sat Mar 14, 2009 9:23 am
I have a 95 F250 power stroke 2X4 i bought last summer a nice clean truck that the previous owner was a snow bird. Being a mechanic/transmission gut i said lets go for a drive and see if the trany has had some work.Well it drove and shifted good (hard and perfect at full throttle) telling me it had been worked on so i bought it $5000.00 then got under the truck later and sure enough it was fresh and had a Gale Banks shift controller and i would recommend that controller to any one.
PostPosted: Sat Mar 14, 2009 11:31 am
Oh yea, I have Banks all over my truck.
PostPosted: Sat Mar 21, 2009 1:57 am
Well I drove it a little on Sat., then on Mon., drove it to work no prob., but on the way home it got hot and started shifting 1st to 2nd soft.
It's at the shop again. I'm waiting to find out what's up. :evil:
PostPosted: Sat Mar 21, 2009 11:25 am
its a 4r100 right, not the E4OD thats for the non DI diesels right?
86trooperT/D 2.2
84 L\B 4x4Diesel LS 2.2
86 L\B 4X4 gas 5 speed 2.3
PostPosted: Sat Mar 21, 2009 11:51 am
It's a 97. It has the Eo4od or something like that. 97 was fairly early into the whole Power Stroke thing. So the trans. was not specially designed for the eng. Just a big block trans. thrown in behind the bigger power.
PostPosted: Sat Mar 21, 2009 7:48 pm
i was told is i cant say its true.......
the first year of the DI fords 1994.5 are all manual transes.
i have yet to find a auto trans 94.5 rig
they tride to put a E4OD behind a DI ford 7.3 on a load test stand.........it blue the E4OD to shreds....... meaning putting parts on the floor 8O in under a day of testing.
its odd that it may have done that becouse the IDI turbo engine is rated at 190hp and the first DI are rated at 210hp. :econfused
the 4R100 is suppost to be better :? i seen the little 4.2 V-6 engines tare them up so i gess its more of a mantnence thing than any thing
my 0.01
if it was me and I had the $$$$ id do a swap to a 6 speed :P
86trooperT/D 2.2
PostPosted: Sun May 17, 2009 12:09 am
I finally got my truck back. Rebuilt trans., a new radiator and trans. cooler, a new short wire harness down by the trans., and .... get this...... a new air filter!!!!! Yea, he figured out that my K&N in the stock air box was restricted and somehow giving the computer wrong signals and causing shifting at the wrong times. It's not that dirty I don't think. I have had it much dirtier before and had no problems. Maybe it's over oiled??? So I have an O E paper filter in there for now. I am checking out a ford truck forum to find out a recommended custom or aftermarket air intake set up.
It shifts very hard now. He said he can soften it if I want. But I think I'll get used to it after a while.
PostPosted: Wed May 20, 2009 5:54 pm
If Dodge finds a K&N in your diesel it will void your warranty.
