It is currently Thu Mar 26, 2026 12:57 pm
PostPosted: Thu Aug 07, 2003 5:13 pm
Hey guys, this question may have been asked before, but I didn't have time to search for it. I have my 350 almost ready to go in my 73 2wd, but I don't have the cash right now for the header kit. I do however have a set of stock "ramhorn" manifolds, which flow really good. Are there still clearance problems with these manifolds? What about a set of blockhugger headers,? Also, JEGS has a set of "streetrod" headers that they say are really good for really enclosed engine bays. If anyone knows anything about any of these products, please let me know ASAP. I can't wait to get it done. I will post pics as soon as I can. It is a 2wd shortbed. Its lowered 7" in front, 6" in the back. I have some aluminum 15" wheels on it- soon to be 16's or 17's.
I just rebuilt my motor. It is a 1971 4-bolt main 350. Edelbrock performer intake, Holley 600 4-barrel carb. Comp cams 292 degree, .490 lift cam. Comp cams valve springs. Summit gear drive. TH400 tranny with a B&M shift kit. I will be running duel 2.5" 40-series Flowmasters. With my cam, it should sound hot! I plan to have a new rear frame section built with a narrowed 9". I have been working on it for about 2 years (off and on). Thanks for the help, you guys rock!
No LUV anymore, but still in the GM truck family. Running a lifted 2002 Silverado Z-71!
PostPosted: Thu Aug 07, 2003 6:43 pm
Thanks anyways guys, I just found an old posting about the same topic that had what I was looking for. Peace
 Post subject: headers
PostPosted: Fri Aug 08, 2003 1:36 am
Heddman Hedders sold me my street rod headers and they worked out fine.
1 5/8" Primaries with 2 1/2" collectors. These will flow better than the ram horns. Tim [/img]
PostPosted: Fri Aug 08, 2003 8:46 am
Japanese Redneck
ram horns are great manifolds if you dont have the $$$ for headers. Larry Dixon (driver for the Miller Lite Top Fuel NHRA team) has a 66 Nova with a small block on the jug. It runs 11.50's all day long on those manifolds. I believe there are 2 different types/sizes though.
PostPosted: Mon Sep 08, 2003 2:12 pm
will they fit though? I could just have the muff shop built and bend pipe up to them right? What about having the pipe run through the fenders like the frame mount headers?
PostPosted: Tue Sep 09, 2003 8:57 am
Japanese Redneck
they will fit. Not sure what you mean by frame mount. Nova guys like me absolutely love Fenderwell headers. I need to get a set made for my truck but block huggers also work very well. A guy out here has a 1936 ford coupe with an aluminum headed small block in the low 10's (probably high 9's by now) and he runs just regular 1 5/8" smalll tube block huggers on his motor.
