It is currently Wed May 06, 2026 2:51 am
PostPosted: Sat Apr 04, 2009 4:09 pm
im trying to take the front end off my luv to test fit the 350 and i dont know how to take the raditor support and the wheel wells i took the fenders off and the grill
75-luv mikado-V8 350 soon
PostPosted: Sat Apr 04, 2009 5:08 pm
It is welded on. You can fab some brackets to bolt it back in if you remove it...
PostPosted: Sat Apr 04, 2009 5:40 pm
Dewalt sells front end removal kit
PostPosted: Sat Apr 04, 2009 11:06 pm
You do not need to remove the front clip nor cut up the top of the radiator core support. Remove the water pump and crank pulleys. It will go right in. You should be able to do the minor mods needed and be good to go. I've done hundreds of these. PM if you need help, as I am local to you. OC.
Check out the instruction sheet on www.photobucket.com/v8luv
PostPosted: Mon May 11, 2009 2:23 am
:lol: :lol: :lol: :lol: :lol:
LUV is...
