It is currently Thu Jun 25, 2026 5:38 am
PostPosted: Tue May 05, 2009 7:35 pm
Question for you guys I pulled the head, water pump and then I took off the main pully but I still cant get the timing chain cover off am I not doing something or what else do I need to do to get the cover off? Thanks for your help I can always count on you guys
chevyluv@gmail.com Email me if you want
Back in the LUV game
For the love of the LUV!
PostPosted: Tue May 05, 2009 9:29 pm
if i remember wright there are 2 bolt in the oil pan the attach to the cover... and if you got the head off you got the 2 by the chain on the inside of the head
PostPosted: Sat May 09, 2009 8:32 pm
I hope you don't have a 4x4 then the easiest way is to pull the engine.
ctmandu is right 2 bolts in the bottom, pan
PostPosted: Sat May 09, 2009 11:01 pm
Thanks guys just got around to drain the pan today and will be pulling it off next week. Thanks again I can always count on you guys here for help
