It is currently Mon May 25, 2026 4:23 am
Post new topic Reply to topic  [ 89 posts ]  Go to page Previous  1, 2, 3, 4, 5
PostPosted: Tue Mar 17, 2009 11:25 pm
X2. Want to see how it turns out. May be one in my future...
PostPosted: Tue Mar 31, 2009 4:03 pm
pics comin this weekend 2 inch primaries long tubes! 8O :twisted: :twisted:
6.0l ls1 swap th350
PostPosted: Fri Apr 03, 2009 6:53 pm
clink on link in my sig for pics of my headers and exhaust
6.0l ls1 swap th350
PostPosted: Wed Apr 22, 2009 11:12 pm
With the switch to a carb, what kind of HP difference are you expecting?
PostPosted: Thu Apr 23, 2009 1:32 pm
from what i read in these chevy magazines on ls swaps running both efi and carb on the same motor the carb is making 15 or more hp. plus my truck is a rat rod and carb is alot cheaper and not as diffucult to run. i would need a good tune to run my cam.
6.0l ls1 swap th350
PostPosted: Thu Jul 23, 2009 10:35 pm
Hey,
Sweet build! Your craftsmanship is awesome, and innovative! I had a question though on your s10 spindles. Is the reason why you are welding in the s10 ball joints because you are using the LUV a-arms? Is it possible to use the s10 a-arms and spindles and bolt them up to the LUV frame?
Thanks,
Ben
Ben
1975 Luv, Street-Strip Build: in progress
PostPosted: Fri Sep 04, 2009 11:55 am
yea used the luv a arms to much work to use s10 a arms. most difficult part would be the bottom ball joints making the plates. works good!
6.0l ls1 swap th350
PostPosted: Fri Sep 04, 2009 12:06 pm
by the way truck is up for sale minus motor tranny and headers
6.0l ls1 swap th350
PostPosted: Fri Dec 30, 2011 7:21 pm
bump for saling truck bboutwell0106@yahoo.com
6.0l ls1 swap th350
Users browsing this forum: Bing [Bot] and 20 guests
