It is currently Thu Apr 09, 2026 2:21 pm
 Post subject: Temperature problem
PostPosted: Fri Apr 17, 2009 9:02 am
Yesterday on my 50 mile drive home (on LA freeways) my truck ran perfect (70 mph in the carpool lane). I stopped at the auto parts store for a few minutes before going home. When I left the store I noticed the temperature gauge around 200 degrees. I figured it would go down once I got moving. On the 3 mile drive home the temperature would go up to around 210 degrees when I was moving and then drop a little when I stopped. When I got home I checked for any water leaks. No leaks. The only odd thing was the radiator was not hot. I was able to hold my hand on the top tank without getting burned. I did notice the over flow reservoir was half full. I released the pressure from the radiator with the cap release and that’s when the radiator started getting hot (lots of hot gases and no water). I added about 10 ounces of water to top off the radiator and started the truck back up. The water in the radiator was churning up real good. The temperature dropped back down to 180 degrees. Any thought on what could have caused this temperature problem. Sorry for making this a long read.
 Post subject: Re: Temperature problem
PostPosted: Fri Apr 17, 2009 9:11 am
sounds like your thermostat is stuck. swap it out, should fix the problem.
A.j.
PostPosted: Fri Apr 17, 2009 10:09 am
When you change your thermostat buy a new ratiator cap as well. Sounds like the spring might be getting weak and not holding the right pressure.....could be why you had alot of fluid in the overflow.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Fri Apr 17, 2009 10:26 am
The cap, thermostat and water pump are only two months old (also had the radiator re-done). The guy who stole it was running without a thermostat. It looks like it might have over heated on him when he was driving it. I'm still in the process of replacing/fixing the things he did to it.
PostPosted: Fri Apr 17, 2009 10:37 am
Do a compression check of the coolant system and cap. Leak may be very small and or just starting. Also do a combustion check in the coolant system. You might have a head gasket that's starting to leak.
Quite often, taking out the thermostadt will make them run hotter.
PostPosted: Fri Apr 17, 2009 11:15 am
new dont mean anything on a thermostat or waterpump. have had many crapo zone and checkers thernmostats not work right out of the box. Most replacement parts from your local autoparts store are of chinese manufactoring and there quality control tends to be sketchy.
better safe than sorry. I always check my t -stat in the kitchen and add 2 small bleeder holes.
A.j.
PostPosted: Fri Apr 17, 2009 1:16 pm
Take out the t stat, and put it in a pan of water on the stove. Heat it up and see if it opens all the way. If you a thermometer you can make sure it's opening at the proper temp.
PostPosted: Fri Apr 17, 2009 3:05 pm
Ditto, I have had several Thermostats go bad right out of the box, that's when I learned to also drill a couple bypass holes as well.
1981 Luv 2WD
1981 Luv parts trk
PostPosted: Fri Apr 17, 2009 9:20 pm
Keep an eye on it, and if it tends to keep getting air in it again, you have a head gasket starting to go.
Sooner or later you will be replacing it.
PostPosted: Wed Apr 22, 2009 1:49 pm
Had the truck in the shop for the past two days and my mechanic could not find a thing wrong. Another mystery.
PostPosted: Wed Apr 22, 2009 2:47 pm
you know, just cause its happened to me.....
i had an el camino that was doing the same thing after put a new engine in..... it turned out that when I had pulled the radiator to swap the engine, the rag I had stuffed in the water outlets had slipped inside and never got noticed during re-assembly.
so, yea... it was the problem i discovered almost a year later.
just a thought?
A.j.
PostPosted: Wed Apr 22, 2009 3:57 pm
Did your mechanic perform a Flow test on the radiator?
1981 Luv 2WD
1981 Luv parts trk
PostPosted: Thu Apr 23, 2009 9:03 pm
Flow test, pressure test on the block, road test. He said he could not find a think wrong. No blockage on the water flow. Putting her back on the road Monday.
PostPosted: Thu May 21, 2009 1:35 pm
Has anyone upgraded their radiator fan. If so what type/make did you use.
PostPosted: Thu May 21, 2009 3:13 pm
your problem boggles me, there is obviously something wrong somewhere and crtuching it with a bigger fan wont help. I run a turbo v6 on my stock radiator with a 12 inch 4 blade fan, averages 185 for the most part and I never have overheating issues. thers something deeper thats causing this!
A.j.
PostPosted: Thu May 21, 2009 5:45 pm
Was this a one time event or is this reocurring? One time, it's possible a bit of crap from the cleaning caused the thermostat to get stuck. Who knows? If this happens each time, I'd have to go with egg. The head gasket comes first to my mind. Good luck and let us know if/when you fix it.
Rick
Loranger, La
1980 Stepside LUV (Again)
PostPosted: Wed Jun 17, 2009 12:45 pm
Took truck back to the shop yesterday. We did a test of the coolant system and the CO was 707 ppm. I think that should point my mechanic in the right direction.
76 LUV
