It is currently Tue Jun 09, 2026 1:28 pm
PostPosted: Thu Apr 09, 2009 10:17 pm
I just rebuilt my 77 luv and it runs great there's 200 miles on it and I haven't gotten it smoged yet but I'm only getting 15 miles a gallon and I thought it would get better so I'm wondering how i can get better gas mileage without putting in a 5 speed or a new carb or new whatever and I have used the search and have not gotten my answer but I have been told its not broken in and it will get better and I was also told I gotta get it smoged so the guy can tune it to where it needs to be so any input would be great. And I would like to keep it as stock as posible.. Thanks
currently working on my 1977 luv truk
PostPosted: Fri Apr 10, 2009 2:21 pm
If it's only 15 than something might be wrong or you might be driving faster than 55mph for most of the time. 15 is the mileage your going to be getting at like 65 or 70 mph. since it's not a 4x4 your rear differential should be 3.73. And your stock tire size is like 25 or 26 inches. The smog won't make a huge difference but you should be at least 20mpg. When I took my smog stuff off I lost 2-3mpg. But I got that back with overinflated tires. The stock carb is kinda worthless but if it's in good shape there isn't much else it could be. Brakes could be dragging, a non-vented gas cap, underinflated tires, air filter, fuel filter, bad timing. Just start going through each one and I'm sure you'll find it. It also would be a good idea to go through your vacuum diagram and make sure you don't have any leaks there. They don't get the best mileage but they're cheap to maintain and they don't break often. Anything else just let us know.
PostPosted: Fri Apr 10, 2009 9:30 pm
hey we got the same truck i like my 77 and drive slower i get i about 25-35 on mine its all stock and wont pass smog so i helped it pass but im gona get the carb rebuilt and than i should get the full mpg outa the truck i can it just suxs we live in cali or i woulda put the 4.3v6 in my 77 speaking im going with the 5.0 sbc v8 in my 75 (speaking thats smog exempt here) back to me trying to help u get alumum wheels lighter liek the ones on my truck and smaller tires if ur got bigger than stock and dont drive with crap in the truck or in the bed les weight is better
75-luv mikado-V8 350 soon
PostPosted: Fri Apr 10, 2009 11:02 pm
and mine is beefed up with weber header and cam and still at about 70/75 i get 25/30mpg city/hwy could your choke be stuck open? just a thought. dont know if it would mater but i was asked that when i was a kid and got bad gas mileage from my 74
PostPosted: Sat Apr 11, 2009 9:48 am
Cat means stuck closed, or partly closed. This would restrict the air going in and make it run rich.... using more gas.
PostPosted: Sat Apr 11, 2009 11:06 am
yep thats what i ment, sorry
PostPosted: Sat Apr 11, 2009 2:23 pm
:lol: I never get things bass ackwords :lol:
Check the electric choke and make sure there is voltage to it and check it for proper operation.
PostPosted: Sat Apr 11, 2009 6:54 pm
Also check the choke linkage that holds the choke open a little with vacuum. The electrically heated spring holds the choke closed and then relaxes, but the vacuum opens it back up. The vacuum diaphragm for the choke is right behind the heated choke spring housing and the linkage runs between this housing and the carburetor barrel. This linkage is hard to see. My linkage came off and my mileage was around 15 mpg. Now that I finally fixed it, while cruising on the freeway and country highways to Sebastopol and back (70 mph on I-80), I get just over 26 mpg. 4.10 gears. Around town is a bit lower. Mine passes smog.
PostPosted: Sun Apr 12, 2009 2:23 pm
I never thought about checking my choke. I get about 20 with 4.10 gears on my 79 4x4 and wondered if I should be getting better because I never drive faster than 60. I've got a weber, pacesetter, and offy. So I don't know why I wouldn't be getting better.
PostPosted: Sun Apr 12, 2009 5:24 pm
i checked my choke and its opening all the way . and i only drive 55 or 60 vacum lines are not leaking and are going to the right places timing is right
PostPosted: Mon Apr 13, 2009 8:04 pm
Brakes are not dragging air filter is fine . I was wondering how the fuel filter could make you wast more gas?
